Warranty Issue Please Help!!! - Rear Window Seal Gen 3 TRD Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ex03, Feb 26, 2018.
  1. Feb 26, 2018 at 7:37 PM
    8102
    8102 Well-Known Member
    British Columbia
    2016 Toyota Tacoma Limited
    VLEDS LED Low Beam Headlights, VLEDS High Beam LED Headlights, VLEDS LED Fog Lights, VLEDS LED Triton Turn Signals and Brake Lights, VLEDS LED Interior Lights, Reverse, Licence Plate Lights, Stainless Steel OEM Exhaust Tip, Leer XL Canopy, Bed Rug, Diablo Grill Logo, mattgecko Engine Compartment Lights and Bed Lights.
    I think your going to be fine, I just had some warranty work done that the Shop Foreman said would take a while because he was going to have to go back and forth with Corporate, he sounded frustrated by the process as well... " Have you tried this? Have you done that?"
    It sounds to me like they have identified the problem and at the end of the day your getting a whole new unit installed - nice!
    It might be that something is out of alignment (maybe the frame) and the seal is not the problem.
  2. Feb 26, 2018 at 7:39 PM
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    Well that's just silly
  3. Feb 26, 2018 at 10:04 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Its insane sometime what we replace when its something very small thats wrong but more often then not the reason is its cheeper labor wise to just replace the whole assembly instead of having the tech remove the entire window and take it apart to the point they can replace the seal then reassemble it and reinstall the whole thing while hoping thats the problem and not a symptom of something else, granted sometimes there are little parts that simply cannot be ordered on their own and only are availably with the entire assembly. One of the guys at my work replaced the whole sunroof track since the little mesh shield that pops up when sunroof is opened was broken but could not be ordered by itself.
  4. Feb 27, 2018 at 9:18 AM
    Ex03
    Ex03 [OP] Well-Known Member
    2017 Red Tacoma TRD Sport
    Now on top of this I have the dreaded air pillar rattle / front speaker grill. HAHA
  5. Feb 27, 2018 at 1:29 PM
    Ex03
    Well I just got off the phone with Toyota. They are going to cover the repair which includes an entire new back window for fixing 1 small window seal.... Crazy... What a pain in the butt, but I guess I am lucky it was resolved within 48 hours.
    tcjacado and shakerhood like this.
  6. Feb 27, 2018 at 1:44 PM
    brianv1980
    brianv1980 Well-Known Member
    Brian V
    Northern NJ
    2016 Tacoma TRD Sport DCSB
    15% tint, in channel rain guards, Infinity door speakers Kicker Tweeters Kicker SoloBaric L5 8" sub, Low Beam HIDs fog light Yellow HIDs, powder coated oem wheels. 265/70-17 wildpeaks OME 887 coils Bilstein 5100s and AAL
    I work as an advisor for Subaru.... Our guidelines are for body glass paint or claims over 2000 we need to call for prior authorization before we can proceed with repairs.... sometimes this can take some time...
    edit .... that seal is probably pressed into the glass and only serviceable as an assembly :)
  7. Feb 27, 2018 at 8:19 PM
    Tracoma17
    Tracoma17 Well-Known Member
    Travis
    2017 Black Tacoma Limited
    Tinted windows, Clear Bra, running boards
    It’s good to hear this all worked out
    What’s the air pillar rattle?
    I got a rattle by my passenger seat like the seat rubbing on the center console or something
  8. Feb 27, 2018 at 8:20 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The "A" Pillar and the Speaker Cover rub together and make noise, you can stick something between them to stop it.
  9. Feb 27, 2018 at 8:32 PM
    Ex03
    Correct. But on a 30-40k truck that is a year old that is sorta bullshit. Dealer really cant do anything for it. It is a design problem. 2 options. 1 put something between them i.e. a business card or felt that is more subtle. 2 is to smack the shit out of the a pillar and it moves forward a bit. This exposes the rub spot and eliminates the sound for the time being. Just keep it in mind if you ever here a annoying noise near your oh shit handle.
  10. Feb 27, 2018 at 8:34 PM
    shakerhood
    Southern Ohio
    Mine seems to only make noise over there on occasion when its cold outside.
  11. Feb 27, 2018 at 8:35 PM
    Ex03
    That is the first symptom. Cold seems to increase the chance of noise. 40 degree mornings in so cal made me notice it more. If you run the heat for 5 min it minimizes it also. So odd.
    shakerhood[QUOTED] likes this.
  12. Feb 27, 2018 at 9:35 PM
    Tracoma17
    Travis
    So is it on the passenger side?
  13. Feb 27, 2018 at 9:35 PM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Not odd at all, parts and metal expand with heat and “fill gaps”. So does humidity versus dry weather.
  14. Feb 27, 2018 at 9:43 PM
    shakerhood
    Southern Ohio
    Yes, PS "A" Pillar and Speaker Cover.
  15. Feb 27, 2018 at 9:47 PM
    #35
    Tracoma17
    Travis
    10-4 thanks
