Warranty question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by highwhey, Feb 20, 2016.
  1. Feb 20, 2016 at 7:44 PM
    highwhey
    highwhey [OP] Well-Known Member
    Alan
    Phoenix
    2016 Tacoma OR m/t
    what is covered in the standard warranty? Say your clutch(unlikely) goes out at 15k miles, is that covered?
  2. Feb 20, 2016 at 7:48 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    It depends, if its worn from abuse of the owner then absolutely no, but if it fails do to a mechanical issue then I would say yes even though it is a wear item.
  3. Feb 20, 2016 at 8:00 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    A clutch is a tricky one. It would have to be proven to be a manufacturers defect to be covered. A clutch burned up at 15k miles could be due to driver error. Basically, non service items will be covered, service items may or may not be, depending on the failure.
