Warranty - who’s used it, and for what
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wwjvd, Mar 31, 2023.
  1. Apr 4, 2023 at 12:07 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    It's amazing how hit and miss warranty work is approved. How the service writer and tech feel that day, can really affect the outcome. Toyota corporate reps are pretty much useless.
  2. Apr 4, 2023 at 2:20 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
  3. Apr 4, 2023 at 3:11 AM
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Vibration at speed, no fix Toyota claims normal characteristic.
  4. Apr 4, 2023 at 5:07 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've got nothing to gripe about:pccoffee:
  5. Apr 4, 2023 at 5:16 AM
    CanoeBum
    CanoeBum Well-Known Member
    Northern WV
    21 White DCSB 6MT
    Bad needle bearing? Suggest that to them, or just install the ECGS clamshell bushing yourself. Assuming your tires are road force balanced anyway.
  6. Apr 4, 2023 at 5:17 AM
    Mkivbren
    Mkivbren Member
    I have my dads 19 dc w/40k right now to throw on a trd exhaust. What is typical warranty on these? He's got what sounds like a very quiet tick at idle - sounds like maybe an idler pulley on its way out and roof weather strip backing out at the joint to the rear.
  7. Apr 4, 2023 at 5:22 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Needle bearing and poorly balanced tires have 2 very different symptoms.
  8. Apr 4, 2023 at 6:01 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Front driver's side wheel bearing went out around 12k miles. Dealership denied with the rationalization that I must have been driving around with loose lug nuts, even though I never had the wheel off. First thing I did when the wobbled started was check that they were torqued, and they were. Not the worst thing to get denied, since it only cost me $65 for the part and a couple of gray hairs teaching my son (kid has the dexterity of a cat), but did not instill confidence in me if something major happens.
  9. Apr 4, 2023 at 6:09 AM
    ANTupLIFE
    ANTupLIFE Well-Known Member
    Anthony
    Chester, VA
    '16 TRD Sport 4x4 DCLB SW
    Timing cover at 98k miles with 100k mile extended warranty. I turned down the third brake light fix. I'm approaching 160k this month, so I'll fix it myself if ever needed.
  10. Apr 4, 2023 at 6:30 AM
    CanoeBum
    Northern WV
    21 White DCSB 6MT
    Yeah and “vibration” on a truck forum has at least 1000 different definitions.
  11. Apr 4, 2023 at 6:43 AM
    Firk
    Firk Well-Known Member
    1 calliper and tailgate slow drop assist mechanism. Turns 5 tomorrow so that’s the end of my warranty. Well worth it haha
  12. Apr 4, 2023 at 7:06 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    So let me get this straight. You are calling the dealership a "stealership" because they didn't have a shock in stock for your truck. And somehow it is their fault it is on backorder. Toyota is one of the few brands that did not have supply chain issues for parts during Covid. I have been with Toyota for several years. And I can count on one hand, how many times I have had a part I needed, be on backorder. I think your expectations are too high. Dealers do not stock every part for every car. Just a fact of life. And I know this from working for 3 different manufactures over 20+ yrs.
    dbyker likes this.
  13. Apr 4, 2023 at 8:44 AM
    Bbrowning620
    Bbrowning620 Member
    Brandon
    Northern Kentucky
    Black 2023 TRD Offroad DCSB
    Just had my ECM replaced because the truck wouldn't shift into S mode (it was like that off the lot).
  14. Apr 7, 2023 at 7:57 AM
    whisky6
    whisky6 New Member
    2017 AC4X4TRDOR
    ~9,000 miles
    "Customer states: Hearing scraping/grinding noise from right rear. Noise is periodic, and changes with speed. Not all the time, may be associated with temperature."
    It took two more visits and test drive with a technician to get this resolved. "Found right rear brake shoe making noise against backing plate as they shift during operation. Cleaned and lubed plate contact points, and adjusted."
    By then the truck had >14k miles and out of 12 month / 12,000 mile warranty for "brake noises and adjustments". Dealer covered it as "1 time customer goodwill."
    Other than a recall for the fuel pump and regular maintenance, all good so far. Approaching 60k miles.
  15. Apr 7, 2023 at 8:29 AM
    #35
    maxus
    maxus Well-Known Member
    2017 TRD OR DCSB V6 MT
    Just rolled 165,xxx miles on a 2017. I've had some warranty work done, all without issue or pushback from the dealership. Wasn't particularly pleased with having to deal with all of it, specifically bought a Toyota to keep from having issues. But overall, I've been pleased with the truck.
    FWIW, that's 165,xxx miles on the original clutch.
    dbyker likes this.
  16. Apr 8, 2023 at 6:07 AM
    #36
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    2023 sr5. 338 miles my power steering stopped working. Dealer replaced the pump and it’s all good now. Must just been defective unit. My truck has the infamous gear whine at around 50-60mph. 2 dealerships and corporate deemed it normal and won’t do anything to fix it. Both dealer foreman’s warned even if Toyota agrees to replace the rear diff it could make it worse and louder. So I’m just gonna live with because it isn’t that annoying. Only other “issue” is I hear what sounds like wind noise around the right rear door and cab. Double cab short bed.
  17. Apr 8, 2023 at 7:03 AM
    #37
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Battery, front pads and rotors were replaced
  18. Apr 8, 2023 at 7:17 AM
    #38
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    GPS not working so replaced H/U. Vibration after front lift so changed front axle bushing twice. Second time with ECGS bushing at no cost.
  19. Apr 8, 2023 at 7:26 AM
    #39
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    AZ Toyota dealers are the best. I went through LHM Peoria, got a nice discount for public safety after knocking the price down equivalent to an SR5. It’s amazing what happens when they don’t pay their sales people on commission.
    Dawelda[QUOTED] likes this.
  20. Apr 8, 2023 at 9:15 AM
    #40
    Dawelda
    Dawelda Well-Known Member
    West of West Phoenix
    20 Tacoma DCLB TRDOR Desert Sand
    2.5" lift w/33" tires, 10K Winch & bumper, camper shell
    Bought mine in Denver at Mountain States Toyota in '19. I don't think they are on commission either. It was a very decent buying experience.
    I think the old days of car buying are gone after COVID, shortages/supply chain issues, business models like Carvana and online buying options. Glad of it, too. :cheers:
    MulletTaco[QUOTED] likes this.
