Warrior Products 2012-2015 Front Winch Bumper Release
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WarriorProducts, Mar 7, 2016.
  1. Mar 7, 2016 at 2:45 PM
    WarriorProducts
    WarriorProducts [OP] Well-Known Member
    WarriorProducts
    2011 Toyota Tacoma / Blue
    Total Chaos Suspension, Fox Shocks, 3" lift, 33" Nitto Trail Grapplers, Warrior Front Bumper, Rear Bumper, Side Steps, Bed Rack, Roof Rack, Side Plates, Entry Guards, Spare Tire Carrier, Lower Tailgate Cover, Wurton LED's
    Warrior Products released a revised version of the 2005 - 2011 Toyota Tacoma Front Winch Bumper that fits 2012 - 2015 model years.
    Front Winch Bumper w/ Brush Guard & D-Ring Mounts (Available for 2012 - 2015 Toyota Tacoma):
    Part Number #4525 - Front Winch Bumper w/ D-Ring Mounts
    Part Number #4535 - Front Winch Bumper w/ D-Ring Mounts & Brush Guard
    • Unique rounded endcaps provide a clean and finished look.
    • Integrated winch plate and D-Ring mounts.
    • Constructed using 3/16″ steel plate and 11 gauge sheet metal.
    • Unique Light Plate Systems allow for use of OEM or aftermarket lighting options.
    • Fog Light Delete Kit and aftermarket LED plates also available.
    • Reinforced winch plate accepts most 8,000 – 10,000 pound winches including larger integrated solenoid winches.
    • Available with or without 1-1/2″ tubular brush guard.
    • Simple bolt-on installation. No drilling required.
    Cape Fear Finn likes this.
  2. Mar 7, 2016 at 4:53 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I like it.
    Any options for LED bars, etc?
  3. Mar 8, 2016 at 8:48 AM
    WarriorProducts
    WarriorProducts
    The bumper's light bucket system has 3 options: Fog Light Buckets (included with bumper), Aftermarket LED Light Buckets (sold separately), and Delete Plates (sold separately). In addition, the front bumper's brush guard is 1-1/2" diameter tubing which is a common size for aftermarket LED light bar mounting brackets.
    Just a note: the center crossbar in the brush guard is also removable - meaning you can install a winch after installing the bumper (in most cases, depending on winch size) and may make the LED light bar installation even easier.
