was going to get this to lift 3" u guys recommend it
Discussion in 'Suspension' started by RDAY, Jun 7, 2009.
  1. Jun 7, 2009 at 7:32 AM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    I was going to order this to lift my truck 3"
    for the front
    http://www.toyteclifts.com/index.ph...ategory_id=64&option=com_virtuemart&Itemid=72
    and also the spacer above to get me the full 3" but im worried because it says its not recommended for use with spacers is anyone else running this?
    and the rear
    but im confused on the rear is this the only thing i need to lift the rear is the shock or do i need to add something to that as well?
    and is this the cheapest place to order this from if this is a good setup?
    Thanks
  2. Jun 7, 2009 at 10:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    When Running a top plate spacer in conjuction with any other lift (or alone for that matter), you WILL wear out the ball joints quickly, and you run the risk of breaking a shock, or other things, if off roading, or hitting larger bumps.
  3. Jun 7, 2009 at 11:44 AM
    RDAY
    NY
    07 Tacoma SR5 4x4
    chris do i have anyother options to get a full 3" from the billy 5100s then?
  4. Jun 7, 2009 at 11:46 AM
    RDAY
    NY
    07 Tacoma SR5 4x4
    also i will not be doing any offroading but i live out in the where there are some rough roads and lots of potholes
  5. Jun 7, 2009 at 11:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought that spacer was thicker....You should be fine useing it. :eek:
  6. Jun 7, 2009 at 11:54 AM
    RDAY
    NY
    07 Tacoma SR5 4x4
  7. Jun 7, 2009 at 12:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You cant set the rear Bilstiens. Just install the AAL, and the new shocks, and your good. For the front, just move the "C" clip up to the top notch.
  8. Jun 7, 2009 at 12:16 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    and this may be stupid question but is this considered a body lift because i was reading another post and they said this is a body lift and they wouldn't recomend it. Would u recommend something else chris for a really good bang for my buck or is this a good way to lift it. Will it look roughly the same as any other 3" lift kit?
  9. Jun 7, 2009 at 12:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Lifting with the 5100's and an AAL, is an Suspension lift, and about the best "Bang for the Buck". :) You'll be happy with this lift.
  10. Jun 7, 2009 at 12:26 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    just a last check b4 i order
    i need front and rear billyy 5100s, 2 front top plate spacers 1/4", UCA's will i be fine with light racing?
    and do i need a front diff drop? what exactly does that do?
    Thanks so much u have been a huge help
  11. Jun 7, 2009 at 1:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The diff drop, drops the front of the front diff 1", thus dropping the front axels 1/2", as some people have had vibrations in the front, and this is said to correct it. Seems like you got everything needed. :)
  12. Jun 7, 2009 at 2:51 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    r u using a diff drop do u think i need it?
  13. Jun 7, 2009 at 3:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not useing a diff drop. Im a Prerunner, so its not needed. Get it, but dont install it unless you get vibes. OR, wait and see.
  14. Jun 7, 2009 at 3:47 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    but i don't really understand i guess its not gonna take 1" away from the lift is it?
  15. Jun 7, 2009 at 3:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. It just lowers the front of the front diff 1". No affect on the lift height.
  16. Jun 7, 2009 at 3:50 PM
    ffblaze911
    ffblaze911 Well-Known Member
    Frederick, Colorado
    TRD OFF ROAD
    Supercharger
    if you get the billys get them from downsouth you can save 150 doing that
