Was told dealer can't do factory order for 2022 TRD Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2016limited, Jan 28, 2022.
  1. Jan 29, 2022 at 7:11 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Part-time rocket surgeon here.
    Kracken65 and Gamma11[QUOTED] like this.
  2. Jan 29, 2022 at 7:11 PM
    Gamma11
    Gamma11 ((‘)) yea, i like the taste
    Andrew
    Northeast
    2024 DCLB OR Bronze Oxide, 2022 T4R ORP Super White
    :bowdown:
  3. Jan 29, 2022 at 7:31 PM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    I had a 2017 OR, sold it and moved onto something else. This time around went with Pro, hopefully. "Ordered" in October, not actually sure it will ever arrive. Having followed the truck markets locally for last 20 ish years and knowing there is a low chance I will keep it longer than 3-4 years, I'm pretty confident the Pro won't actually cost much more, if any, to own compared to the OR once it's all said and done. Both would only depreciate a few grand in that time period.
  4. Jan 29, 2022 at 7:36 PM
    SpeySquatch
    2016 TRD OR DCSB
    how do you figure it won’t cost much more? I paid $36,400 for my OR out the door. I know the PRO runs at least $8-$10k more than that
    $10k is a nice chunk of change to turn into something more. Money is a tool
  5. Jan 29, 2022 at 7:55 PM
    greengs
    AB, Canada
    Biggest cost to any new vehicle purchase is depreciation. I know I won't keep it past 3-4 years. So my thought is that either OR or Pro will only depreciate around $5k or so looking at history, constant price jumps on new ones, and extremely low Tacoma depreciation (even without Covid).
    ex. Pro, buy for 50k, sell for 45k
    OR, buy for 40k sell for 35k.
    Each truck only "cost" $5k to own as everything else would be roughly the same. Each truck could depreciate more or less, but the Pro isn't going to depreciate that much more to make it depreciate $10k more somehow in that short of time frame. Maybe location determines this, but I'm very confident that won't happen where I live.
    And yes I do agree with you about the $10k up front over that 4 years could be used as opportunity to turn it into $2-$3k potentially if one was good at making money work for them. So that's not accounted for in the example.
  6. Jan 30, 2022 at 12:35 PM
    gdgraph
    gdgraph Well-Known Member
    Northern Virginia
    2020 TRD Pro
    This sounds correct to me. You don't "order a TRD Pro" but you can contact different dealerships and get on their list for a Pro and usually twice a month the dealer gets an allocation list (for all the Toyotas they are getting) and if there's a Pro they then can call you and if you want it you can put a deposit down. That's if the dealership is nice enough to do that, that's why by the time you see one on a dealers website and call it's already sold.
    I'd recommend calling around, find a dealer that does not put market adjustments on the Pros and get on their list (you may have to call 10 dealerships and be willing to drive over an hour away). In my area, within a 1.5 hour radius I only found 2 dealers that didn't do market adjustments and I asked to go on both of their waitlists and the first one to get one in the color I wanted I put down a $500 deposit and called the other to cancel my spot. When I put the deposit down, I had them give me the spec sheet, the total price breakdown and then it was signed by a manager.
    Most of the time, if you see a Pro online, it's one of two things, it's either too late and someone already did the above and put down a deposit, or that dealership sucks and has a big market adjustment, hence why nobody wanted to reserve it.
  7. Jan 30, 2022 at 12:37 PM
    EmollientFoil
    EmollientFoil Well-Known Member
    '22 Army Green SR5 Trail Special Edition
    Couldn’t have said it better
    gdgraph[QUOTED] likes this.
  8. Jan 30, 2022 at 12:39 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Kinda. We can request a certain truck to be made. More often than not, if the dealer is in good standing with Toyota, Toyota will build it. It will however take FOREVER. 6-8 months. If you’re in Ontario I can get you whatever you want ordered from Toyota.
    s0dhi likes this.
  9. Jan 30, 2022 at 12:51 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    This is interesting. Let me ask you something. Are you sure this isn’t just semantics? To me an “order” means the manufacturer builds the car just for you, just the way you want, altering their manufacturing process/cycle/order to do so. Requesting a build and getting it 6-8 months later sounds like waiting for that vehicle to pop up in the preconceived manufacturing plan, and it gets allocated to your dealership. Those are two distinct things.
    Also, will Toyota build you a non-standard vehicle? For example an OR with a color that’s not on the OR spec sheet? Or say, build you an OR with a hood scoop, or a Sport with a locking diff, etc? If the answer is yes then that’s a custom order. If not, I think allocation is still the correct term. Another way to say it perhaps is, it sounds like what you’re talking about is advance allocation. Which would explain the long lead time.
    Again, semantics, but I’m curious.
  10. Jan 30, 2022 at 1:22 PM
    2016limited
    2016limited [OP] Member
    Sounds like in the U.S. this can not be done for some reason....
  11. Jan 30, 2022 at 1:27 PM
    2016limited
    I have contacted a couple of dealerships already and to be honest, they have been less then helpful and I am being nice. No one has offered to put me on a list. They tell me they do not get many Pros and do not know when they are coming in, would you like to buy something else?
  12. Feb 5, 2022 at 10:13 AM
    gdgraph
    Northern Virginia
    2020 TRD Pro
    There are many dirt bag dealerships out there and many won’t reserve because they want it on the lot so they can charge a $5-10k mark up for having it available immediately. You really have to shop around and prepared to go up to 2 hours away.
    I literally called 20 dealers. I had to have a list to cross off the names of ones that did mark ups. Within a 1.5 hr radius I only found 2 dealers that didn’t do mark ups and only one that would put me on a list.
    If your area sucks worse than mine, you can try dealers that will ship. Go on FB and join as many TRD Pro groups and you’ll find dealers that advertise no mark up and delivery.
    I’ll admit, it’s not easy work, but if you put the time in you’ll be rewarded!
  13. Feb 5, 2022 at 10:24 AM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    That's what I told my brother... He was planning to get 4Runner Pro... I told him to get offroad instead. So after he finished with researching/dealing with the dealers, he got offroad instead of Pro. So far, he likes his 4Runner.
    I went by his house and noticed that he got offroad.... I was like "I knew it!"
    SpeySquatch[QUOTED] likes this.
  14. Feb 5, 2022 at 10:48 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    They have no problem selling what they make. The reason they do it is to streamline their manufacturing process. The best a dealer can do is to try to find one or an allocation for one that fits what you want.
  15. Feb 5, 2022 at 10:49 AM
    #35
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Whether the vehicle has hit the lot yet or not has no impact on whether the dealership can charge a market adjustment.
  16. Feb 5, 2022 at 12:54 PM
    #36
    dowNNshift
    dowNNshift Well-Known Member
    When I bought my TRD Pro last year I had to drive 4.5 hours away north of Dallas to a dealership that had one. All the local Austin dealers were playing ugly games with either market adjustments or grossly bloating the costs of the Houston Port installed accessories. I test drove two different ones locally, but as soon as it was time to start negotiating the trade of my old 2016 TRD-OR for the Pro it became insulting. So my best advice is to cast a broad net and be willing to drive to a different region to buy what you're looking for.
    I lucked out because the dealership I purchased mine from had accidentally ordered two without any port add-ons, which was exactly what I was looking for. The sales guy was under pressure from his boss to sell it to fix his mistake, so I got a pretty amazing deal considering. Granted this was Jan 2021 right before the world fell off the cliff with the processor shortages, etc... I found it using Capital One's Automotive tools which showed actual inventory on partnering dealership lots.
    A year in to owning it and I'm very happy with my purchase. It feels much more refined than my first year 2016 did and has a factory PRO upgrades. The only negative I can say is that the gas mileage is worse than my 2016 had, but its probably because this truck is heavier with the mods I've done and my commutes are pretty short.
  17. Feb 6, 2022 at 6:31 AM
    #37
    gdgraph
    Northern Virginia
    2020 TRD Pro
    Obviously a dealer can charge a mark up either way if they want. What I am talking to is that in my area dealers that charge $10k mark ups won't let you reserve a Pro, so generally they aren't "presold" and sit on their lots longer.
    Dealers that do allow you to put a deposit down ahead of time often don't ever have any on the lot and by the time they post it on their website, it's too late because someone's already reserved it.
  18. Feb 6, 2022 at 6:37 AM
    #38
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Can't you go into the dealership and buy one?
    Last year, 2021 I went to two different Toyota dealerships on the same day and each dealership had a TRD Pro sitting on their lot for sale.
  19. Feb 6, 2022 at 6:43 AM
    #39
    Clearwater Bill
    Billy
    Largo Florida
    True. Because.......
    Tip. Unless they have exactly what you want, already on the lot or in the allocation stream, avoid Gulf States and SE Toyota regions like the plague.
    Because they play massive games at the port that the dealer cannot control.
    Hook78[QUOTED] and G2.M6 like this.
  20. Feb 6, 2022 at 6:47 AM
    #40
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    I had refundable deposits out in 4 regions before I found my Lime taco. It's an automatic, I still have 4 deposits out on a manual. If and when I find the manual I'll be selling the auto for what I have in her.
