Was wondering if anyone is....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rob1, Sep 1, 2009.
  1. Sep 1, 2009 at 10:01 AM
    rob1
    rob1 [OP] Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Was wondering if anyone is running this www.evanscooling.com in their engines??
    Any problems,suggestions,concerns?? With the weather we have been having here in deep south Texas over 100 the past 3 weeks I was thinking of adding this to keep the temp down in my taco & sienna!!
  2. Sep 1, 2009 at 10:07 AM
    thestrangebrew
    thestrangebrew AlphaPlanner
    Brian
    Dos Palos CA
    TRD 4x4 Rugged Trail Edition
    Black Badges, Black Center Console
    Never heard of it. Does temp. being so high drastically affect the engine? Here in CA it's been scorching for the last few weeks. Other than coolant I never thought of it...
  3. Sep 1, 2009 at 10:09 AM
    rob1
    Robert
    South Texas
    HEAT is a killer to engines, the cooler the engine the better mpg and hp!!
    Especially if you off-road!!
  4. Sep 1, 2009 at 10:27 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    The manual says not to mix coolants. Stick with the pink super long life OEM coolant.
  5. Sep 1, 2009 at 10:28 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Moot point but heat kills power but help mpg
  6. Sep 1, 2009 at 10:45 AM
    rob1
    Robert
    South Texas
    Would'nt mix it, drain what I got and add this stuff!!
    BUT my ??? is has anyone used it??
  7. Sep 1, 2009 at 11:05 AM
    rob1
    Robert
    South Texas
    bump
    Anyone??
  8. Sep 1, 2009 at 11:14 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Running too cool can kill your engine as well. If that weren't true, you wouldn't have a thermostat in your cooling system. Your thermostat is designed to let the engine heat up to a certain temperature before it allows coolant to flow. As long as you're operating at the designed temperature of the engine, I wouldn't worry about it.
  9. Sep 1, 2009 at 12:43 PM
    rob1
    Robert
    South Texas
    bump
    Does anyone use it when off-roading??
  10. Sep 1, 2009 at 12:49 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I guess you will be the first :D
  11. Sep 1, 2009 at 1:54 PM
    rob1
    Robert
    South Texas
    I guess I am...LOL:rolleyes::D
    oh well
  12. Sep 1, 2009 at 2:40 PM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    EXCEPT on Mazdas....from experience those lil pos's like heat much more than cold...thing ran like shiiiiiiiiiiiiiiiiiiiiiit when it was cold. Ran perfectly and got better mileage and was noticeably faster when it was like 95+ out.
  13. Sep 1, 2009 at 4:50 PM
    gcwaterski
    gcwaterski Well-Known Member
    I seriously do not think this stuff will make your engine run "too cool" I ran engine ice on all my motorcycles with no problems. I am curious about this stuff as I want to use an aftermarket fluid in my truck.
  14. Sep 1, 2009 at 4:55 PM
    URBIKESUCKS
    URBIKESUCKS Well-Known Member
    Ron
    Prescott AZ
    2014 DCSB TRD OR
    I have redline water wetter in now no issues.
  15. Sep 1, 2009 at 4:59 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    x2 My buddy is an AMA Superbike mechanic on the side and he runs that engine ice in his bikes. I think vehicles would be the same way. Try it. Nothing bad is going to come from it.
  16. Sep 1, 2009 at 5:02 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yeah your engines need to be at a set temp (not too low or too high) to run their best, I think this stuff would be good if your doing heavy duty off-roading for long periods of time when the temp outside is real hot. And if you plan on taking your truck to race in the Baja 500. :)
  17. Sep 1, 2009 at 5:10 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    an engine's thermostat is still 196 degrees on most vehix as far as i know. Running synthetics usually reduces heat( might be worth considering). At some point , the cooler and less heat u have build up, u jst keep the thermostat shut longer.. nothing more. Watch your temp guage on a hill on a 100+ day. By now you should know by if you have a cooling problem.
    I'm sure the product is good, but they all seem to prey on your fears " heat kills engines" .... only if its overheating. The all say get better mpg , more hp..... you will get more women... sorry I'm digressing again.
