Was your flat repairable on the road? (Poll)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by excorcist, Feb 18, 2017.
Was your flat tire repairable on the road?
  1. Yes, by using a plug kit.
    58.6%
  2. Yes, by re-seating the bead.
    3.4%
  3. Yes, other.
    10.3%
  4. No.
    41.4%
Multiple votes are allowed.
  1. Feb 22, 2017 at 3:26 PM
    Joe D
    Joe D .
    :boink:
    So take that. :angrygirl:
    The majority of my "off road" driving is around my property so it's not an issue BUT, and obviously depending where & what type of wheeling as well as what caused your flat, will impact if it's fixable on the fly.
    All but a few flats for me have been fixable roadside. The one time it wasn't was front & rear right side tire side walls where sliced open by an unknown object making a need for two spares.
  2. Feb 22, 2017 at 4:11 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I wouldn't carry a second spare.
    I do carry a full size matching spare, full assortment of tire tools, and air compressor. The plug kit is king. I'll plug a tire right on the axle and keep going. I'm only swapping to spare if it's a blow out or sidewall slice.
    I run a heavier load E tire which offer greater resistance to punctures, especially when aired down.
    excorcist[OP] likes this.
  3. Feb 22, 2017 at 7:32 PM
    Pigpen
    Dan
    Northwest Montana
    FTFY
    excorcist[QUOTED][OP] likes this.
  4. Feb 22, 2017 at 8:10 PM
    excorcist
    excorcist [OP] Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Had to look up FTFY, lol thanks... I think my grammar has been waning since college.
    Pigpen[QUOTED] likes this.
  5. Feb 22, 2017 at 8:16 PM
    Pigpen
    Dan
    Northwest Montana
    To answer the actual question... almost all of my flats have been repairable, even on bald passenger rated tires. I did cut a little close to the side of a Forest Service Road once on a corner where a fallen tree had been cut (mostly) out of the road... I hit the cut end of the tree with the sidewall of the tire and blew a hole on it you could fit your fist through. OOPS!
  6. Feb 22, 2017 at 8:39 PM
    excorcist
    Reno, NV
    That has been my experience as well, sidewall damage has only happened where it could have been avoided, in my case deep ruts and once in a mud puddle when I was younger. Thats not to say it can't happen in other situations, but overall Im really thinking one spare tire and a plug kit is plenty.
    Pigpen likes this.
