washed my engine and now...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kessler89, Oct 14, 2010.
  1. Oct 14, 2010 at 5:36 PM
    kessler89
    kessler89 [OP] Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    I have this chirping from under the hood, if I drive it for 10min it'll go away?? The belt looks ok, any ideas?
  2. Oct 14, 2010 at 5:51 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Water doesn't kill belts.
    Don't spray high water pressure on the motor, drive belts
    You will be fine. Just don't do it again
  3. Oct 14, 2010 at 6:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Most "chirping" sounds from the engine are from an Idler pully.
  4. Oct 14, 2010 at 6:38 PM
    chacotaco
    chacotaco Well-Known Member
    Travis
    Albuquerque & Palo Alto
    2011 SSM TRD SPORT DCLB
    Black Snugtop XtraVision Sleep Deck.
    Sounds like you got water in a pulley. Some people who have snorkels and diff/tranny breathers have an issue with this.
  5. Oct 14, 2010 at 7:53 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    hmm.. mine chirps every morning when i first start her up. I have to let it run about 5 minutes to stop it. Pisses me off since it doesnt every time i start it in the morning.
  6. Oct 14, 2010 at 8:11 PM
    ink junky
    ink junky I phucking hate people >:(
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    Once there was a sudden chirping in the cab of my truck, I soon found out that there was a fuckin cricket in the truck...
    haha, but thats not your case :D
  7. Oct 14, 2010 at 8:16 PM
    Jeff3004x4
    Jeff3004x4 Well-Known Member
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    Carefully spray the bearing in your idler pulley with some sort of oil (DON'T GET IT ON THE BELT!) If the noise goes away, it's your pulley. It will slowly get worse, I wouldn't worry about it until it makes noise all the time. Run it!
  8. Oct 14, 2010 at 8:56 PM
    supataco
    supataco Shaq-enzy Falls
    Ichiro
    Oahu - Hawaii
    2010-SSM-AC-TRDSport-PreRunner
    -17" 4Runner Trail Wheels (265/70/17) -OEM Tube Steps -Tailgate Security Clamps -Trimmed Mudflaps -Bed Bar -Kobalt Box -Bed Mat -Toyota Mats
    LMAO
  9. Oct 14, 2010 at 11:27 PM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    it never did it untill i washed the motor, pisses me off it's still doing it, drove to work and home and it still did it for about the first 10min of my drive, i'm gonna throw a new belt on it tomorrow might not do anything but i planned on changing it anyways, sounds coming from the tensioner and i really dont wanna change it, but i dont wanna drive around in a truck that sounds like it's 20 years old either
  10. Oct 15, 2010 at 9:39 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    While you have the belt off check your pulleys by hand, if one seems a little rough or the bearing is dry its likely your culprit.
    You can remove the pulley and repack the bearing with grease if you wish. Just remove the seal with a small pick or similar and inject some of the appropriate grease. You can even press the bearings out and remove both seals if you wish to do it all the way. Press the bearing back in and your golden for the install.
    I tried to source the bearing that Toyota uses but its a part manufactured for Toyota exclusively. A bearing can be purchased with the same outside diameter, but the inside diameter is greater (hole for mounting bolt) - therefore you will need a bushing or spacer such as the ones supplied with the Rock Auto pulleys for mounting.
  11. Oct 15, 2010 at 10:15 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    Well I pulled the belt off and the top drivers idler pulley had about 1/4in free play while all of the others had none and this is the side the noise was coming from I ordered a new one and it'll be here today, gonna change it after work and ill post back
  12. Oct 15, 2010 at 10:47 PM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    well i replaced one of the upper idler pulleys and slapped a brand new belt on it and..... it's as quiet as a mouse, thank god cause it was getting annoying!!
  13. Oct 15, 2010 at 10:54 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    glad you got it worked out. This is why I don't wash my engine.
  14. Oct 15, 2010 at 11:53 PM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    guess i wont do that again! turned into a $80 engine wash!!
    at least it's kinda clean now
  15. Oct 16, 2010 at 8:22 AM
    ink junky
    TACO LOVER
    TEXAS
    how should you clean the engine bay?:confused:
  16. Oct 16, 2010 at 8:23 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I just don't. It stays pretty clean as long as you don't go through some really deep mud or something.
  17. Oct 16, 2010 at 8:28 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    :spy:
    this is how mine looks all the time....
  18. Oct 16, 2010 at 8:49 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    Yeah aparently the previous owner never cleaned mine either, with good reason I guess!
  19. Oct 16, 2010 at 8:59 AM
    Fortech
    CANADA
    There's no problem with washing the engine, but there are a few areas of concern that shouldn't receive a direct blast of water.
  20. Oct 16, 2010 at 9:10 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Hindsight being 20/20 (and not being a smartass) ...... perhaps before the change out you should have done a "deep" cleaning.
