Washer fluid light help.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shabutie, Nov 13, 2013.
  1. Nov 13, 2013 at 2:21 PM
    Shabutie
    Shabutie [OP] Well-Known Member
    Zach
    Fort Stewart
    2002 Toyota Tacoma Limited 4WD 4dr
    I ran my truck out of washer fluid, so my light came on. I put some more in there and not it wont turn back off. It's rather annoying and yes I put enough in it. Thanks guys
  2. Nov 16, 2013 at 2:01 AM
    lunch box
    lunch box diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    check the level sensor maybe its stuck. you should be able to unplug the sensor and the tank hook a multimeter to the sensor and as the float goes up and down your ohms should go up or down you must understand sensor speak a different language and the language is voltage so the resistance caused by the sensor will go up or down dependent on the fluid level.
