washer nozzle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jesseunvoas, Oct 10, 2010.
  1. Oct 10, 2010 at 9:46 AM
    jesseunvoas
    jesseunvoas [OP] Well-Known Member
    Jesse
    Swift Current, Sask, Canada
    08 TRD SPORT
    3" Ready Lift Super 80 Muffler AFE Stage 2 CAI Pro Dry Filter OEM Roof Rack RollBAK Tonneau Cover Cooper AT3 Tires Kakays On The Roof free candy topper
    ok so i went through my second nozzle since owning my truck and have lost faith in the toyota nozzles, just wondering what some of you are using to replace the crappy stock ones
  2. Oct 10, 2010 at 9:48 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    never heard of an issue...
  3. Oct 10, 2010 at 9:51 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    i never had an issues with my nozzels...have you tried using a paper clip to just unclog the nozzle from the top and bottom? that may help...
  4. Oct 10, 2010 at 11:43 AM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    I would use compressed air. Not full pressure because you will just blow the lines off but you can blow through both ends. At the tank, then the nozzle. Typically it is caused by something getting in there and clogging it. Check the tank for any dirt or muddy goo. Clean as necessary. Replace wash fluid with some concentrate and try to not let it get diluted down too much as the gooey mold will grow again and clog things.
    That was really complicated just for a nozzle... wow
  5. Oct 10, 2010 at 11:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2. :confused:
  6. Oct 10, 2010 at 12:06 PM
    jesseunvoas
    Jesse
    08 TRD SPORT
    it's not clogged the center portion came loose from the body and doesn't shoot at all
  7. Oct 10, 2010 at 12:33 PM
    Taco11
    Seattle WA
    You mean the nozzle came apart? Thats odd.. when does it happen? Like do they pop off while using them?
  8. Oct 10, 2010 at 12:51 PM
    jhodge83
    SC
    is it possibly affected by the weather up there? freezing up in the winter and it causing something to split or break apart?
  9. Oct 10, 2010 at 12:52 PM
    Taco11
    Seattle WA
    This is what I am thinking as well...
  10. Oct 10, 2010 at 12:52 PM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    For clogged nozzles I have found CLR on a q-tip works great. For a nozzle that came apart your probably boned.
  11. Oct 10, 2010 at 12:56 PM
    jesseunvoas
    Jesse
    08 TRD SPORT
    i haven't owned the truck in the winter yet i will take a pic of the nozzle for you guys
  12. Oct 10, 2010 at 12:58 PM
    jhodge83
    SC
    damn...breaking twice and no winter....weird. i've never heard of anyone having an issue like this at all.
  13. Oct 10, 2010 at 1:06 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Had no issues with my truck and winter. And they've frozen up a few times. Just get out, wack the ice off and away you go.
  14. Oct 10, 2010 at 1:47 PM
    jesseunvoas
    Jesse
    08 TRD SPORT
    here its on the truck and i took it off since it's useless the way it is
    the center part is loose i can center it but his a bump and it falls to the bottom again
  15. Oct 10, 2010 at 3:19 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Funny...I had a problem with mine the first day I bought it. I don't know what they replaced...whether the nozzles or the pump itself. Haven't had a problem since.
  16. Oct 10, 2010 at 4:31 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Yours is silver? Weird. Mine is black.
  17. Oct 10, 2010 at 4:33 PM
    Taco11
    Seattle WA
    Pics don't work for me.. anyone else see them?
  18. Oct 10, 2010 at 6:09 PM
    tx_shooter
    That's a negative, Ghost Rider.
  19. Oct 10, 2010 at 6:11 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    They work for me
