washers for Carrier Barring drop
Discussion in 'Suspension' started by KingMoo, Dec 19, 2011.
  1. Dec 19, 2011 at 10:17 AM
    KingMoo
    KingMoo [OP] Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    what kind of washers am I looking for for a home-made carrier barring drop? ex. square? outside length? inside diameter?
  2. Dec 19, 2011 at 10:34 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    5/16" x 1-3/16" x 2-9/16"
    Hole diameter = 3/8"
  3. Dec 19, 2011 at 12:05 PM
    KingMoo
    Calgary
    Tacoma TRD Sport
    I remember reading that some people just used spare washers found around the warehouse. If so I would assume they're square. Is that OK too?
  4. Dec 20, 2011 at 7:33 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2006 Tacoma double-cab TRD Sport
    Homertaco grill, Light Racing UCA's, 2.8" front lift (5100's at 0.85 setting and Eibach springs) 2" AAL with rear 5100's, Wet Okole seat covers fr/ bk. 17 x 9 Incubus Crusher wheels w/ 4.5" backspacing. 30% tinted front windows.
    I belive you can get square washers at hardware stores. Run a string from the front to rear lower edge of your drive shaft, and pull it tight. I did that and found the CB was higher by ecactly 3/8" so the OME CB drop worked perfect for my application. If you get a measurement you will know how much of a drop it will take to straighten things out. Let us know how she goes.
