Washing the engine?
Discussion in '4th Gen. Tacomas (2024+)' started by Gfenza89, Aug 25, 2024.
  1. Aug 25, 2024 at 5:35 AM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Anyone washed their engines yet? I washed mine for the first time with a foam cannon. Just wrapped tin foil around the air intake and soaked the engine with suds and rinsed it off, fired right up after I was done. Deff was little nervous. Figured I’d let you guys know it will be fine if you were on the fence about doing it.
    Mudc4t, batman900, Lexpd1145 and 2 others like this.
  2. Aug 26, 2024 at 9:38 AM
    thedudeabides22
    thedudeabides22 Well-Known Member
    2024 Tacoma 4x4 TRD Offroad
    Wow! I am way to scared to do that. Pics of before and after by chance? No pressure washer I assume?
    Jakerou likes this.
  3. Aug 26, 2024 at 9:40 AM
    Gfenza89
    No pictures sorry. No pressure washer. Just my foam cannon hooked up to my garden hose.
  4. Aug 26, 2024 at 10:23 AM
    hemlockz
    hemlockz Well-Known Member
    24 Bronze ORP 6MT
    How did it get dirty?
    It should be fine in theory, right? Last time I washed out an entire it got a CEL the next time driving. After unclipping some wire connectors and drying out with a cotton swab and reconnecting it went away though.
    TurboDA6 and Gfenza89[OP] like this.
  5. Aug 26, 2024 at 10:29 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  6. Aug 26, 2024 at 10:40 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    I've been driving for almost 40 years, and not once have I ever lifted the hood and hit the engine bay with water.
    Is this a toktik thing?
  7. Aug 26, 2024 at 10:44 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    No it’s a people who clean more than the paint thing
    Clean engine bay and underside of salt
    atc250r, ridefreak and Goin2drt like this.
  8. Aug 26, 2024 at 10:50 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    There should be no fear in washing a modern engine. Something from the 50's, 60's, maybe into the 80's, especially carbureted ones, yeah, be careful with those (wash them still, but just be careful). But anything from roughly the 90's-00's and newer should be no problem in terms of washing. I regularly wash the engines of all our vehicles. I never cover anything. And while I don't use super high pressure I do use a pressure washer now. Modern engines and electronics are very well protected from water.
    Also, as another example... you see those off-road guys in Tacoma's, Jeeps, Land Crusiers...etc doing water crossings where the engine is essentially submerged? Those guys are just fine so you shouldn't worry in the slightest about hosing yours off.
    ridefreak and TurboDA6 like this.
  9. Aug 26, 2024 at 11:07 AM
    HoosierBuddy
    HoosierBuddy Well-Known Member
    Phil
    2012 Base Regular Cab 4WD Manual
    2" Lift
    I've been washing my engines fairly regularly since the 1980's. Maybe twice a year on every vehicle I've owned. I've never had any issue.
    I just get it wet and use a soapy brush on it, kind of like I would wheels....then hose off the suds. Start it up and drive off.
    At some point, this may cause an issue, but for the last 40 years it hasn't.
    TurboDA6 likes this.
  10. Aug 26, 2024 at 11:16 AM
    TurboDA6
    TurboDA6 Well-Known Member
    We have a new Toyota, a new Nissan and an old Acura in our home fleet.
    I regularly clean the engine bays in those vehicles, about twice a year. Never any issues.
    If you perform your own work on your vehicles, it's nice to keep them clean inside and out. Makes servicing easier, and less crap to fall into your engine should you need to pull a valve cover or intake manifold.
    Nothing wrong with leaving it dirty either. If you don't work on it yourself, really doesn't matter.
    Modern vehicles should have zero problems with under hood cleaning. Only when they get significantly older, the seals on electrical connectors get old, allow water in, and then you'll have an issue. Anything less than 20 years old should be in good enough condition to tolerate water spray.
    atc250r likes this.
  11. Aug 26, 2024 at 11:21 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I do it from time to time. I currently have an oil leak that I'm trying to find. I used my pressure washer to soak the engine with soap and a degreaser. Let it sit for a while and blast it off. You need to find where the fuse box it and avoid hitting it with high pressure as well as the air intake. Once cleaned it made it easy to find the leak. Truck is in the shop new being repaired. I'll clean it again when it gets back.
    I did pull the air filter before starting the truck afterwards just to be sure no water got into the air intake. It was perfectly dry.
    FWIW, my dad started driving in 1936 and he regularly cleaned his engines up until he stopped driving around 2010.
  12. Aug 26, 2024 at 11:30 AM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Once I soaked my Alternator a bit too much....result?! Had to replace the Alternator!
  13. Aug 26, 2024 at 11:31 AM
    ScrippsRanch67
    Bob
    Fiberglass shell
    I even use Simple Green to kill ants that find their way into my kitchen!
  14. Aug 26, 2024 at 11:38 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    Pressure wash is fine, just don't be differently-abled about it and keep the nozzle minimum of 20" from anything. Cleaning agents not needed unless you got a leak or made a mess somewhere. I wash my engine bay probably once every 6 times I wash the truck. Plain water. If you can, let it cool a bit first. Have done this for more than two decades with zero problems or issues.
  15. Aug 26, 2024 at 12:26 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    RCBS likes this.
  16. Aug 26, 2024 at 12:30 PM
    Goin2drt
    Goin2drt Well-Known Member
    Yep. Been driving for 39 years and always have a clean engine. Back in the day you had to cover the distributor cap and airbox inlet but aside from that been cleaning the engine in all of my 20+ cars I have owned. When I sell or trade in a car people always pay way more for the care they have been kept in.
    RCBS and TurboDA6 like this.
  17. Aug 26, 2024 at 1:32 PM
    RCBS
    Never needed the simple green. If I want to spruce it up nice, I hit it with silicone spray afterwards.
    TA2016[QUOTED] likes this.
  18. Aug 26, 2024 at 1:38 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Regular formula simple green is terrible for aluminum. Wouldn’t use that! But I also don’t waste my time washing engines, unless we’re talking motorcycles
    MagicToolbox and ace_10 like this.
  19. Aug 27, 2024 at 4:43 AM
    Nordicbeast
    Nordicbeast I wanna be sedated...
    '23 TRD Pro 6MT
    I wash the engine bay of all of my vehicles once a year....caked on grime/dirt traps engine heat and just looks messy. Start with a cool engine, put some baggies or saran wrap over electrical connectors, spray with a degreaser, let it sit for a bit, use a plastic stiff bristled brush to scrub off the heavy crap then rinse with a gentle stream of water from a garden hose (I would NOT use a pressure water as you can force water into electrical connectors and corrode them from the inside out). You can then dress the plastic bits with 303....
    Gfenza89[OP] likes this.
  20. Aug 27, 2024 at 4:54 AM
    Clearwater Bill
    Billy
    Largo Florida
    No tiky no laundry.
    I've been keeping my engine bays spiffy since the late 60s via various methods, including self service car wash wands, garden hose, Tire foam cleaner, simple green, and elbow grease.
    Everything from old Chevy 6's to our current RAV and Tacoma, including Z cars, Miata, Mustang, Hondas, GTOs, etc.
    I worked for a guy who specialized in Pontiacs one summer, and sometimes he'd send me to the car wash to clean the nasty bay of a customer's car before he'd even work on it.
    ridefreak likes this.
