Washing truck with salty well water
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, May 22, 2019.
  1. May 22, 2019 at 6:57 PM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    Hello quick question I use water softener in my water filtration system since I have well water I was spraying down my frame since I went to the beach and was worried about my frame and was washing it down with my well water and was wondering since the well water has salt in it wouldn't it be just as bad I don't want to harm my frame .
    Running Board Man likes this.
  2. May 22, 2019 at 7:53 PM
    Vann
    Vann Well-Known Member
    Garth
    Weisenburg, PA
    '04 x-cab 4x4, 2.7 5sp. "The Black Pearl"
    stock
    From a former plumber, no.
    tcBob and Wyoming09 like this.
  3. May 22, 2019 at 10:03 PM
    Glamisman
    Glamisman Well-Known Member
    one trick to do before you go play at the beach and salt water is to spray the underside with WD-40. The WD in WD-40 stands for "water dis-placer" and it was the 40th attempt at the formula. As an added benefit when you get home and hose it off dust, dirt and mud wont stick to anything... this is an old dirt biker trick to keep the bike clean between runs.
    95GLH, GQ7227, Sebz13 and 1 other person like this.
  4. May 23, 2019 at 12:34 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you can drink the water from your well after the water softner your fine .
    I remember those days water so hard soap would hardly do anything till the water softner was installed what a difference
    GQ7227 and cruiserguy like this.
  5. May 23, 2019 at 2:15 AM
    Tacomaislife
    Texas
    2002 tacoma trd
    we can't drink the water I was told it needed a diffent kind of system to make it drinkable or somthing like that he just didn't recommend drinking it
  6. May 23, 2019 at 2:36 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The softener should not be putting salt in the water. The salt in the soften is used for recharging ziolite beads in the softener. Most of the salt stays in the softener.
    Secondly, don't be retarded and run your car in the ocean. You can never remove all the salt.
    Minimag95 likes this.
  7. May 23, 2019 at 2:47 AM
    Indy
    Indy Master of all I survey.
    A softener adds trace amounts to the water but we're talking trace. It's measurable but not enough to matter.
  8. May 23, 2019 at 2:50 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    [QUOTE="Wyoming09, post: 20685439, member: 153833] If you can drink the water from your well after the water softner your fine .
    I remember those days water so hard soap would hardly do anything till the water softner was installed what a difference[/QUOTE]
    ^^^^ I agree. ^^^^
    One of the tasks I had on my first job way back when I was a teenager was maintaining a water softener on a large ice machine. Keeping it full of salt, back-flushing it every day, etc. I wondered back then why the ICE didn't come out salty as hell. I still don't understand the why, but do know that a properly functioning water softener does NOT put out salty water.
    Wyoming09, GQ7227 and koditten like this.
  9. May 23, 2019 at 3:11 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Do you realize how much salt they put on the winter roads is Michigan?
    GQ7227 likes this.
  10. May 23, 2019 at 3:32 AM
    koditten
    Kirk
    Central Michigan
    Yes.
    Exactly why I posted. Why would anyone on purpose coat their truck with salt? I think it makes me an athority.
  11. May 23, 2019 at 4:01 AM
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    It should be fine. The typical concentration of salt (sodium) in seawater is 35,000 parts per million (ppm). The recommended drinking water sodium limit is 200 ppm. A water softener system that uses sodium does impart sodium into the water, usually resulting in a concentration less than 200 ppm. A water test for sodium will give you a better idea.
    GQ7227 likes this.
  12. May 23, 2019 at 5:21 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i am trying to neutralize the salt with a proper mixing of fairy dust, still working on the formula!
    koditten[QUOTED] likes this.
  13. May 23, 2019 at 8:57 AM
    Tacomaislife
    Texas
    2002 tacoma trd
    I was park about 10 feet from the ocean I was worried about the salt spray in the air
  14. May 23, 2019 at 8:59 AM
    koditten
    Kirk
    Central Michigan
    Thank you for being smart. I read quite often about people driving in the surf with brand new trucks. It's mind boggling.
  15. May 23, 2019 at 8:59 AM
    Tacomaislife
    Texas
    2002 tacoma trd
    Do u recommend city wate in washing the frame I am most denfinally going to fluid film
  16. May 23, 2019 at 9:03 AM
    koditten
    Kirk
    Central Michigan
    Not going to make any difference. There is usually no softened water to outside garden hose spickets. No one would use sift water to water their yards. Only a few dedicated auto detailers are going to have soft water for washing cars.
    Your well water will work just fine for washing the frame.
    Fluid Film is a win! I've done 3 Tundras and 2 Tacomas this spring so far.
  17. May 23, 2019 at 9:26 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    The concentration of salt in the well water is orders of magnitude less than the salt from the ocean or from winter salting of the roads.
    Worst case scenario is that while not perfect, it's certainly better than not washing it at all.
    You could always just take it to a car wash, too. The DIY kind, not the drive through ones.
    SilverBulletII likes this.
  18. May 23, 2019 at 9:28 AM
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    1995 Tacoma SR5 4x4, the bottom bitch. 2018 Tacoma 4x4 DCSB OR, wife's truck.
    95 - Rust 2018 - '19 Pro grille, Westin HDX drop steps, Spidertrax 1.5" spacers
    Finally someone who gets it. WD-40 is not a lubricant.
    GQ7227 and Tacomaislife[OP] like this.
  19. May 23, 2019 at 11:07 AM
    SilverBulletII
    New England
    City water would be fine.
