Washing under the hood
Discussion in 'Detailing' started by bowhunter95, Aug 27, 2012.
  1. Aug 27, 2012 at 7:33 PM
    bowhunter95
    bowhunter95 [OP] Member
    TJ
    Illinois
    Black Lifted tacoma
    Went mudding a few weeks ago. Now would it be bad if I washed down the motor and everything else inside the hood? I don't want to screw anything up. Thanks
  2. Aug 28, 2012 at 11:28 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Stick a pressure washer in there(not too close...) and blast all that mud to heaven :) Then wipe the underside of the hood as best you can...i hate that some of the mud gets inbetween the metal where you can't get too..
  3. Aug 28, 2012 at 11:48 AM
    tacowestley
    tacowestley Khmer Member
    Wes
    562/626, CA
    05 DC Prerunner OR
    8k HIDs, flowmaster, bora wheel spacers 1.25'', debadged tailgate, DRL and foglight anytime mod, BHLM, 09+ LED tailights, painted valence black, mickey thompson classics 16'', switchback LEDs, reverse LEDs, tailgate clamp
    After i came back from off roading the next day i spray the whole engine with simple green, let it sit, then rinse it all off and wipe clean then your good! :D
  4. Aug 28, 2012 at 11:55 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Just avoid getting water in your intake and dont prolong spaying anything electrical and you'll be fine
  5. Aug 28, 2012 at 2:31 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Always felt nervous with a pressure washer personally. Maybe it would've helped because I used a garden hose on light spray with a couple different kind of sponges. Also too the engine cover off because there was a ton more under there. Went back and did a chamois cloth wipe down, repeated once or twice as needed.
    Went through this fairly recently. Will think twice about diving into mud after that. I couldn't even see the top of the battery when a friend lifted the hood on his truck after mudding.
  6. Aug 28, 2012 at 2:33 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You will be okay using a pressure washer as long as you dont sit there and hose it down for an hour. After you spray it off take a little drive to heat everything back up so it dries faster.
  7. Aug 28, 2012 at 6:08 PM
    bowhunter95
    TJ
    Illinois
    Black Lifted tacoma
    Thanks guys
