Washington State shop recommendation for CMC or relocation?
Discussion in 'North East' started by Chipperchas, Jan 17, 2021.
  1. Jan 17, 2021 at 8:48 PM
    Chipperchas
    Chipperchas [OP] Member
    2018 cement tacoma TRD OR
    Stock as a MF
    Does anyone know any knowledgeable shops, or even any locals, preferably in puyallup-tacoma or in the pierce county area who would be willing to do the fabrication of a cab mount relocation? Im completely stock on my rig at the moment but am pre planning for my lift and bigger tires. Thanks in advance for any help
  2. Jan 17, 2021 at 8:59 PM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    MULE in Issaquah
  3. Jan 17, 2021 at 9:00 PM
    Chipperchas
    Stock as a MF
    Awesome, i was looking at them, but it seemed more like an accessory shop and wasnt sure if they would do the fabrication it takes
  4. Jan 17, 2021 at 9:01 PM
    PuyallupJon
    Jon
    Puyallup, WA
    2020 Tacoma
    For sure they will do the chop and my guess is whatever else you want. Drive up there and talk to them. Very popular joint.
  5. Jan 17, 2021 at 9:02 PM
    Chipperchas
    Stock as a MF
    Awesome thank you! Ill def have to do that
  6. Jan 18, 2021 at 6:18 PM
    PNWTacoAdventures
    PNWTacoAdventures Well-Known Member
    Washington
    2020 Super White Tacoma TRD OffRoad
    What size lift, wheels and tires are you going with? I didn’t have to do a CMC and went up 2.5 with 285/70/17. No rubbing at all.
  7. Jan 18, 2021 at 6:22 PM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    No bias, so gonna list in alphabetical order.
    Auburn Off-Road
    Badland Bumpers Mfg
    Mule
  8. Jan 18, 2021 at 6:23 PM
    msgs350
    PNW
    Some Mods
    what’s your wheel spec and do you have UCA?
    I’m lifted about 2.5” with JBA UCA and rub with 285/70-17 Nitto Ridge grapplers, wheels are 17x8.5 -10.
  9. Jan 18, 2021 at 6:36 PM
    PNWTacoAdventures
    Washington
    I am running Camburg UCA, 285/70/17 BFG KO2. SCS Ray 10 17x8.5 -10. No front mud flaps. Not rubbing at all even reverse full turn. 6112 on 4th notch w/Bilstein 650lb springs
    msgs350[QUOTED] likes this.
  10. Jan 18, 2021 at 7:54 PM
    Chipperchas
    Stock as a MF
    Im still completely stock but have been looking at 3" lifts and want to run 34s or 35s, i just figured start with the cheap and easy stuff and then make it easier down the line
  11. Jan 18, 2021 at 7:55 PM
    Chipperchas
    Stock as a MF
    I was looking at auburn offroad, hows their fabrication work?
  12. Jan 18, 2021 at 8:47 PM
    msgs350
    PNW
    Some Mods
    I’ve read good things about them, never had fab work done there. I’ll need some hammer hangers installed soon so I might give them a call. before you buy parts, call these shops in case they don’t let you bring your own.
  13. Jan 18, 2021 at 9:19 PM
    PNWTacoAdventures
    Washington
    You will want to look at doing some gears as well if your going to 34’s or 35’s
  14. Jan 18, 2021 at 9:58 PM
    Chipperchas
    Stock as a MF
    That will probably be my next step after the CMC, ive heard even stock it helps with the searching for gears and the low end tq, ill probably just do a weekend in wenatchee and have nitro install them for me
  15. Jan 18, 2021 at 9:59 PM
    Chipperchas
    Stock as a MF
    That is actually a good idea, i forgot some shops dont allow you to bring your own parts. If anything ill just find someone local who could weld it up for me
  16. Feb 3, 2021 at 8:20 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Hey not sure if you got the info you needed but just letting you know you posted this in the north east section instead of the north west
  17. Feb 3, 2021 at 8:25 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If Badland is open right now, they'll let you bring your parts
