Water Bypass Pipe No.1
Discussion in '4 Cylinder' started by SMS909, Jan 27, 2012.
  1. Apr 24, 2016 at 5:41 AM
    toddwarren2
    toddwarren2 Gig 'em Ags!
    Todd
    Stuart, FL
    2006 2.7L 4-cyl Tacoma 4x4
    3" MotoFab strut spacer 3" SkyJacker Add A Leaf LiquidMetal 20" chrome wheels 275/55/20 Pirelli Scorpion tires TPMS hack (to turn off the blinking light) 1" filter for the 2ndary air pump (emissions control BS)
    charosenz- your TB is much older than mine (06), so I'd rather not give you bad info. Anybody have a similarly aged TB who can answer?
  2. Apr 24, 2016 at 11:08 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    That's what I figured - I do 99% of my own maintenance but if I do it it will come at a inconvenient time and I'll have to remove the manifold to get at it - with the engine out it should just be 4 bolts out and in. I don't know what the average life of a plastic pipe is but I intend to keep the truck until it dies or I do which ever comes first so its bound to crack sometime. Thanks 4 the reply.
  3. May 17, 2016 at 6:06 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    I'm going to revive this thread kind of. Just an FYI the Water Bypass pipe you used is actually for a different engine. The correct one is in my other post. I'll post the number in just a few min.
  4. May 17, 2016 at 6:13 PM
    2.7taco
    Texas
    Correct part number.
    16268-75130
  5. May 21, 2016 at 6:37 AM
    2.7taco
    Texas
    Update. Tacoma under the knife and Toyota is footing the bill due to selling me a part not designed for the 2.7 Tacoma.
    cosmicfires likes this.
  6. May 21, 2016 at 4:24 PM
    george3
    New Jersey
    Congratulations.
  7. May 21, 2016 at 5:32 PM
    2.7taco
    Texas
    Thanks.:D
  8. May 21, 2016 at 7:54 PM
    2.7taco
    Texas
    Looks good so far repair took them a bit. Time will tell if every thing sealed properly.
  9. Jun 12, 2016 at 1:11 PM
    SnowB0und
    SnowB0und Well-Known Member
    4cyl 4x4
    How much was the metal pipe from Toyota? I'm tempted to replace it before I have a problem. All the BMW's I've had have had random plastic cooling system failures, so I'm against plastic...
  10. Sep 6, 2016 at 6:09 PM
    2.7taco
    Texas
    Sorry to get back with you so late. I don't remember the cost on the pipe itself. What I do remember is the pain in the butt other was to replace. You will need a new intake manifold gasket as well.
  11. Sep 19, 2016 at 9:06 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I have a 2004 and after coming across a thread like this before I went and checked mine because I figured I'd better replace it before i have a problem 40 miles from no where. It sure seems to be steel, not plastic and I know it has never been replaced. When did they switch over to plastic for this part. Does anyone know?
  12. Sep 20, 2016 at 8:29 AM
    toddwarren2
    Todd
    Stuart, FL
    Sometime between yours (2004) and mine (2006) they switched to plastic. Ain't that some BS? I'm not sure if my replacement was for an earlier year (like yours) or not. The replacement tube had a little tab on it about mid-way between the thermostat housing and the back (near firewall), so I was curious myself as to what that was for. It was not in the way and the plastic version (the one that failed) did not have the tab. Looked like a wire clamp or tube retainer of some sort would attach to it.
  13. Sep 21, 2016 at 9:15 PM
    TRVLR500
    Wyoming
    Plastic sucks for just about anything as far as I am concerned. Especially on a part like this coolant tube. I still can't get over plastic radiators but they do seem to work.
  14. Oct 1, 2016 at 2:12 PM
    richarddeath
    richarddeath Member
    [/QUOTE]
  15. Oct 1, 2016 at 4:30 PM
    #35
    richarddeath
    richarddeath Member
    I have just got EXACTLY the same thing happen on my fortuner 2.7 vvti, can find anything online apart from you post...thx for posting btw..! where did u get the by pass pipe from...im out in st kitts - caribbean and will need to get one fedexed over ASAP. ant help EVERY much appreciated thx
  16. Oct 3, 2016 at 12:28 PM
    #36
    richarddeath
    richarddeath Member
    Ok, all done... managed to get the part on island. RE Collant do i just top back up or do I have to bleed the system of air ..??
  17. Oct 10, 2016 at 4:03 AM
    #37
    toddwarren2
    Todd
    Stuart, FL
    Sorry for the delay in getting back to you. Had a little hurricane to manage! LOL I got my part from the dealership. I had to call around to find one and ended up driving about 45 miles to get one. Well worth it.
  18. Oct 10, 2016 at 4:06 AM
    #38
    toddwarren2
    Todd
    Stuart, FL
    Whoops, sorry! I see that you got it done. I just added coolant, ran the engine and kept adding it as the engine "burped" thru the radiator fill valve. It will force the air up to the top of the radiator per design, but add as much as you can at first. Keep some coolant with you and top off as needed, but shouldn't need too much. Glad my post helped!
  19. Oct 18, 2016 at 4:15 AM
    #39
    richarddeath
    richarddeath Member
    Thank you, I seem to have some air in the system....as on a longer drive steam is coming back into the coolant bottle, it seems to be getting less but still happening. Any suggestions...someone mentioned taking one of the pipes off from the back of the by pass pipe but im really not sure.. ANY help would help. Thx
  20. Oct 18, 2016 at 5:31 AM
    #40
    toddwarren2
    Todd
    Stuart, FL
    We'll have to wait for some else to chime in as I didn't have this problem. I'm not sure where/how you got air trapped in the system. I mean, mine completely puked all the coolant out when I changed my lower radiator hose, thermo and coolant tube. My only concern is that you have an air-leak somewhere that's allowing for air to be sucked into the system. I'm dubious that's the case because you'd probably have a coolant leak versus an air-vacuum situation. Very odd. I would have thought that the system would have purged any trapped air by now. Hopefully your engine isn't over-heating (i.e. too little coolant circulating in the engine, etc). I assume you would have mentioned that if so.
