Water Bypass Pipe No.1
Discussion in '4 Cylinder' started by SMS909, Jan 27, 2012.
  1. Nov 30, 2019 at 3:14 PM
    #121
    Markcal
    Markcal Well-Known Member
    We are approaching winter here in the Northeast with some cold temperatures and without a garage to replace the pipe, spring with warmer temperatures will be when I plan to replace it, if it holds out till then. :fingerscrossed:
    BassAckwards[QUOTED] likes this.
  2. Nov 30, 2019 at 4:16 PM
    #122
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Just keep a close eye on the coolant level and you should be good to go
    Markcal[QUOTED] likes this.
  3. Nov 30, 2019 at 4:17 PM
    #123
    BassAckwards
    I checked mine daily after i realized it was leaking while i was waiting on my pipe to come in
  4. Dec 16, 2019 at 3:05 PM
    #124
    pwrslide2
    pwrslide2 Well-Known Member
    AZ
    07' 2.7 2wd auto
    In process
    I need to do mine now. I was just checking where hoses went, trying to figure out what hoses I could easily replace as preventative maintenance and I barely touched/wiggled the upward barb/nipple or whatever you call it along the firewall and it busted.. . at least it didn't do it on the road or somewhere other than at home.
    any recommendation of other P#s to replace other than the pipe and subsequent gasket that goes with it?
    Hoses? PVC lines?
    Anyone have the P#s for the soft lines that come off of the Heater core?
    I find this site and others that run off the same Toyota listings a little ambiguous https://parts.camelbacktoyota.com/v...l4-gas/hvac--evaporator-and-heater-components
    pipe 16268-75130
    pipe gasket 16258-75021
    intake manifold gasket 17177-75040
    intake manifold TB seal 22271-0D051
    I plan on doing the Valve cover gasket, spark plug gasket, spark plugs, PCV
    valve cover gasket 11213-75041
    spark plug gasket 11214-75012
    PCV valve 12204-0C010
    Radiator cap (seal feels and looks crusty), Upper and lower radiator hoses(look original)
  5. Dec 17, 2019 at 8:25 AM
    #125
    agalloch07
    agalloch07 Well-Known Member
  6. Dec 17, 2019 at 8:29 AM
    #126
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
  7. Dec 17, 2019 at 9:11 AM
    #127
    agalloch07
  8. Dec 17, 2019 at 9:17 AM
    #128
    agalloch07
    lol never mind camelbacktoyota.com wants $25.58 to ship it Total for the pipe and gasket is $79.06 HAHAHAHA..... Ebay it is.
  9. Dec 17, 2019 at 9:38 AM
    #129
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    I'm picking up like 25 parts from my local dealer, the one in the link, for $10.00. So almost free shipping if you pickup. I even ordered a new front grille.
  10. Dec 17, 2019 at 9:59 AM
    #130
    agalloch07
    I will check my local dealer im sure their price is more than $10 though. Even the metal bypass pipes China is selling are $13 i might order one just to see what the quality is like Toyota may have outsourced them to China. https://www.ebay.com/itm/For-Toyota...30-16268-75110/173853499067?fits=Model:Tacoma
  11. Dec 17, 2019 at 1:24 PM
    #131
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    Dude... . It's not $10 for the pipe. I ordered a bunch of parts thru the website and it's $10 for them to collect and store the parts until I pick them up. They have to pay for shipping stuff to them if they don't have it in stock so it's essentially a shipping and processing charge.
  12. Dec 18, 2019 at 8:02 AM
    #132
    96carboard
    96carboard Well-Known Member
    While I don't dispute that there may be an issue with the water pipe, there is no logic to support your assumption that a "problem" has been in any way "acknowledged" based on a part being changed. Improving something does not necessarily mean that there was something wrong with what is being improved upon.
    To spin the concept to its extremes, the biggest difference between the 2005-2015 models and the 2016+ is a minor change to the shape of the body panels. Does the fact that they changed the shape of the body panels imply that Toyota has "acknowledged" that there was a problem with the body panel shape?
  13. Dec 18, 2019 at 8:09 AM
    #133
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    odd argumentative line there. The plastic parts that bolt to the engine and transmission fail randomly. some experience it as little as 60K miles in my very short amount of research. Manifold removal is not easy. This part was not meant to be changed out like a typical coolant line.
  14. Dec 18, 2019 at 8:10 AM
    #134
    96carboard
    Try actually reading what I said.
  15. Dec 18, 2019 at 8:25 AM
    #135
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    oh, so you wanted people to respond with something outlandish like your body style comment and not made from common sense deduction or Engineering prowess?
  16. Dec 18, 2019 at 8:37 AM
    #136
    96carboard
    No. I expect that if people want to have a civilized conversation, that they actually make an attempt to understand what they are responding to before they put their foot in their mouth as you have.
  17. Dec 18, 2019 at 8:40 AM
    #137
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    ahhh. seems like your signature(quoted below) supports my assumption that you like to troll a bit but don't like responses to your trolling. got it. that was your first POST in the thread.. . interesting
    "If you are retarded, then you're either already on my ignore list, or soon to be added.
    Don't expect any replies from me."
    ColoradoTJ and BassAckwards like this.
  18. Dec 18, 2019 at 8:44 AM
    #138
    BassAckwards
    @pwrslide2 dont even bother responding to this guy. He goes all over the forums and makes comments like these just to start shit. Best to just ignore folks like this. Obviously toyota saw the problem with the plastic pipes and made the change to metal ones around 2010. No point in debating that with this guy. Toyota didnt upgrade them to steel bc that would help their bottom line lol. They did it to cover their own ass
    Hayrider, Markcal, ColoradoTJ and 2 others like this.
  19. Dec 18, 2019 at 9:11 AM
    #139
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Agreed he's the biggest a hole on the forum
  20. Dec 18, 2019 at 9:40 AM
    #140
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    What's oddly Ironic is that BMW M and S series motors have a coolant line like this and my 98M3 does have a tiny leak coming out of it randomly (127K). Slightly different design. Metal, however and not many issues for BMW owners. but mainly the gaskets go bad or the pipe rusts(not SS on most motors but they did upgrade to SS on some over the years). equally hard to replace if not harder because there is a massive rats nest of wiring, coolant, PCV and IAC lines under there.
