Water concern
Discussion in 'Florida' started by Hungryholler, Apr 24, 2011.
  1. Apr 24, 2011 at 6:00 PM
    Hungryholler
    Hungryholler [OP] Member
    Pensacola, FL
    2006 4x4 4 door silver
    Stock...so far.
    Hello all,
    So, I took my Taco into Jones Swamp (Pensacola FL area) on Saturday...wow! The locals who knew the area well said it wasn't too bad because of lack of rain.
    However, seeing as how I just got my truck, and seeing as how i'm still new to most of this, it was still pretty damn scary, especially the video below.
    After I did the mini crossing, I did a bit of research on the topic of water fjording and learned that I probably should have done a diff breather mod, and probably a radiator fan switch (again...researched this AFTER I did it..not smart I know).
    So now I'm paranoid a little that I may of messed up my radiator fan clutch. It's making bit of noise (or a noise in that general direction), but not bad. I'm not even sure it wasn't there before...but now I'm just hyper sensitive to any/all sounds!
    What do you guys think? Was this too deep? Am I being too paranoid? I'm not scared to use it for what it was built for...but I don't want to damage my truck!
    Also, I do plan on changing my diff oils soon...
    Thanks for time.
    See the video..sorry for the cuss word if that bothers you.
    http://www.youtube.com/watch?v=v7xSnDnO6js
  2. Apr 24, 2011 at 6:04 PM
    rev25sharp
    rev25sharp Well-Known Member
    Al
    jacksonville fl
    Silver 17dcsb trd sport
    i use to live in pensacola cantonment area(north pcola) where is jones swamp? my guess is your truck should be ok
  3. Apr 24, 2011 at 6:15 PM
    ben76
    ben76 Well-Known Member
    Ben
    New Port Richey, Fl
    Yea, I wouldn't be to worried about that. You where only in it for a second, not really long enough for anything bad to happen.
  4. Apr 24, 2011 at 6:18 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    sweet!!!
  5. Apr 24, 2011 at 7:06 PM
    Hungryholler
    Pensacola, FL
    Stock...so far.
    Sweet. I guess I should have mentioned that I did a few of those crossings of about the same depth...in and out. After I did the crossings, nothing made me think I had broken something. I guess i'm just paranoid right now.
    Although....I read in a FJ cruiser forum that a guy had to replace his idler pulleys after a crossing. It was quite a big bigger though....on the Eglin Rez.
    Anyway, thanks for helping me alleviate some of my worries. I'm still gonna be careful though!
    Jones Swamp is a few miles past Corry Station's shopping exchange gate. The trail starts right next to Arbys.
  6. Apr 24, 2011 at 7:09 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    yeah I think you're ok lol
  7. Apr 24, 2011 at 7:14 PM
    Hungryholler
    Pensacola, FL
    Stock...so far.
    Cool. Thanks guys! I gotta say...the Tacoma is an extremely capable truck. It is completely stock, with fairly crappy tires...not even ATs, and it didn't miss a beat. I saw a few other trucks/jeeps that were stuck in the same areas I went through.
    Anyway, thanks again!
    Rondog, I assume your lol'ing because i'm acting like a ninny! Lol.
  8. Apr 24, 2011 at 7:22 PM
    ben76
    Ben
    New Port Richey, Fl
    Sounds about like the place we have down here called Richloam. Nothing but swamp and lots of water. If you can catch it at the right time and the waters down, it's a lot of fun.
  9. Apr 24, 2011 at 7:30 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    The switch you're talking about is for electric fans, to shut them off during crossings. The main issue with our fans is that the metal blades can be shoved forward into the radiator causing damage. Your fan clutch is probably fine, as are your idler bearings. There have been issues with the 1GR-FE idler bearings but going through water like that occasionally, you're fine.
    As for the rear diff, it's possible you sucked water in, but not likely. You can pull the rear diff fill plug and stick a finger in there, if it's milky then you know it's contaminated and you need to change it, if not you're good to go.
  10. Apr 25, 2011 at 4:36 AM
    Hungryholler
    Pensacola, FL
    Stock...so far.
    Ben76...that place looks like a blast.
    Thanks for the advice Maxamillion.
    Take it easy guys....and thanks again!
