Water Crossings
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mountain_Jordan, Jun 29, 2022.
  1. Jun 29, 2022 at 11:43 AM
    mountain_Jordan
    mountain_Jordan [OP] Well-Known Member
    BC, Canada
    2021 TRD OFF Road DCSB
    Good Day Taco World!!
    I have a question about water crossing when out wheelin.
    I have a '21 Off Road, and was out last weekend crawling around some trails and did a number of river crossings and drove down an ephemeral channel, wonderful adventure...
    Is there any concern regarding waterproofing of the underbelly components?
    A friend of mine mentioned something about water getting into certain areas (Dif ?) and I just want to make sure I am not damaging anything, or if certain maintenance is required, that I complete it.
    It is purely recreational at this point, but it still exposes the truck to several short crossings.
    Thank you for your help!!
    Jordan
  2. Jun 29, 2022 at 11:48 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Anything that contains oil can get contaminated if any seals or breathers fail. Depending on depth, the intake is just inside the right fender liner so there is risk of sucking water there too. That being said, I have spent a lot of time in water up to the rocker and after changing diff fluid, there was no water in it at all. YMMV
  3. Jun 29, 2022 at 11:49 AM
    Tacospike
    Two Trucks
    How deep do you think it was?
    Junkhead likes this.
  4. Jun 29, 2022 at 11:50 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Many people extend the rear diff breather higher up. Besides that, I purely avoid any water thats going to be higher than halfway up the wheels.
  5. Jun 29, 2022 at 11:50 AM
    mountain_Jordan
    BC, Canada
    Touching the frame, bottom of the doors in some quick dip spots
    SR-71A likes this.
  6. Jun 29, 2022 at 11:55 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The diff is a concern. The breather is a 1-way breather (only allows pressure out), so when your differential is hot and you submerge it in cool water, it can create a vacuum and pull in contaminates from the axle seals. There are a few posts here on TW where this has happened.
    If you wish to continue doing water crossings, I would recommend installing a breather like the one by ARB and install it somewhere high where it will not be submerged.
    Key-Rei and mountain_Jordan[OP] like this.
  7. Jun 29, 2022 at 11:57 AM
    mountain_Jordan
    BC, Canada
    Awesome, thank you for this info! I was just watching a video about doing a breather mod.
    TnShooter and ktbell444[QUOTED] like this.
