water dripping from exhaust pipe whats going on?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 00toytaco, Dec 14, 2012.
  1. Dec 17, 2012 at 2:35 AM
    #41
    00toytaco
    00toytaco [OP] Well-Known Member
    Joshua
    Loveland, CO
    00' Tacoma SR5 w/TRD V6 4x4
    Home made intake system (need to get the right system), Rancho rear shocks, kyb front struts, 3 inch lift, brushguard, home made grille, Dual led 6.5" speakers, 12" JL Audio sub.
    I usually run seafoam through the gas tank once or twice a year. But if i'm going to take the time to clean the TB i might as well do it right. For the TB gaskets would it be better to use rtv blue or black? I put all new fluids, spark plugs, and spark plug wires in not to long ago. I'm running Denso Platinum spark plugs, bwd wires, and Castrol GTX High Mileage oil. Truck is a 2000 and it has 227,674 miles on it had 120,000 when i got it in 2003.
  2. Dec 17, 2012 at 2:46 AM
    #42
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    your mileage will drop off in winter.
  3. Dec 17, 2012 at 3:05 AM
    #43
    00toytaco
    Joshua
    Loveland, CO
    I get 15 mpg on average and in winter using High 4 the mpg seems to be better actually and more torque in cold weather.
  4. Dec 17, 2012 at 3:09 AM
    #44
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    well colder air has more oxygen in it
  5. Dec 17, 2012 at 3:13 AM
    #45
    00toytaco
    Joshua
    Loveland, CO
    truck likes the cold i dont :)
  6. Dec 17, 2012 at 3:18 AM
    #46
    00toytaco
    Joshua
    Loveland, CO
    Just thought of this. With all the water coming out of the exhaust pipe wouldn't that be a possible cause for the o2 sensor to throw codes?
  7. Dec 17, 2012 at 3:40 AM
    #47
    00toytaco
    Joshua
    Loveland, CO
    what is a canooter h20 bypass valve?
  8. Dec 17, 2012 at 4:28 AM
    #48
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    nah that wont throw it. what codes does it throw exactly?
  9. Dec 17, 2012 at 5:23 AM
    #49
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    O2 sensor and air fuel sensor just had the exact same issue and code reading. Order Denso's from Amazon cheaper than from the parts store.
  10. Dec 17, 2012 at 4:44 PM
    #50
    00toytaco
    Joshua
    Loveland, CO
    i cant check the codes apparently when i fixed the intake last night its keeping the check engine light off for now. Also SoutheastTaco said most likely be a bad canooter h20 bypass valve? ive asked all kinds of people and part stores and nobody even heard of one of those. so what is it?
  11. Dec 17, 2012 at 5:33 PM
    #51
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    It's a device that is up on the left part of the firewall. Next to the Flux Capacitor.
  12. Dec 17, 2012 at 7:04 PM
    #52
    00toytaco
    Joshua
    Loveland, CO
    Have any pics of this device?
  13. Dec 17, 2012 at 7:07 PM
    #53
    HBMurphy
    Paul
    So California Coast
    None
  14. Dec 17, 2012 at 7:31 PM
    #54
    00toytaco
    Joshua
    Loveland, CO
    I know i dont know much about vehicles ive only been learning mechanics for 6 or 7 years now but i know enough to know whats true and whats not. There is no such thing as a h20 bypass valve and about the flux capacitor my truck is a 2000 tacoma bot a 1960's delorean. Get your facts straight or dont reply to my thread.
  15. Dec 17, 2012 at 10:09 PM
    #55
    HBMurphy
    Paul
    So California Coast
    None
    That was my way of telling you someone was pulling your leg. The condensation is normal when burning gasoline in the correct air/fuel mixture. :)
  16. Dec 17, 2012 at 11:04 PM
    #56
    00toytaco
    Joshua
    Loveland, CO
    Haha k sorry its been a long day. Ill just change where i get gas which was shell, western, or king soopers just a few hours ago filled up on 91 at diamond shamrock plus put some water treatment see what it does after awhile. What are some good places in my area to get gas?
  17. Dec 17, 2012 at 11:06 PM
    #57
    00toytaco
    Joshua
    Loveland, CO
    Thats if anyones around the larimer county, colorado area.
  18. Dec 17, 2012 at 11:16 PM
    #58
    00toytaco
    Joshua
    Loveland, CO
    Also a correction on the delorean not 1960's first year of production was 1981.
  19. Dec 18, 2012 at 2:06 PM
    #59
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Im a little confused here. Are you still haveing the "water out of the tail pipe" issue or is there another issue you are trying to fix?
  20. Dec 18, 2012 at 5:37 PM
    #60
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    :laughing:
