Water dripping from overhead console & interior light.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kryten, Dec 12, 2012.
  1. Dec 12, 2012 at 11:27 AM
    kryten
    kryten [OP] Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    A few days ago I noticed quite a bit of water dripping from my overhead console (compass and light) and also interior light. The weather was about -20 to -25C that day and a few days prior to that. It was fairly cold before that too. I noticed water dripping after I pulled outside of a heated garage where I was parked for about 20 minutes while unloading stuff. This was right after a four hour highway drive in -20C weather.
    I don't have a garage so I always park outside. Initially I thought it was condensation since my windows always ice up inside in winter, but it was a fair bit of water so it made me concerned. I always clean my truck from snow, even sweep the roof so I don't have a foot of snow sitting on top...
    I had my windshield replaced last winter with a cheap aftermarket one. First I thought it may not be sealed well anymore, but I would think water would be leaking down the windshield and would not get as far as overhead console let alone interior light.
    That all happened last Sunday. Yesterday (Tuesday) temparatures climbed to -2C or so, so I went through a long overdue carwash. Again there were a few drips of water from overhead console and some moisture in the interior light. Much less than on Sunday.
    Now I'm thinking it may be roof rack molding that is leaking? I don't have OEM roof rack and as far as I know the previous owner did not have one installed.
    Any thoughts? Everything looks OK on quick inspection.
  2. Dec 12, 2012 at 11:34 AM
    BamaToy1997
    Bill
    Navarre, FL
    If you have a roof rack, I would look at that. It would have a higher probability of causing water to collect at the overhead. Perhaps pull off the side edge molding at the door and poke a flashlight over the edge to see what you can above the headliner?
    hammertime4005 likes this.
  3. Dec 12, 2012 at 12:01 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd pull the headliner and have a look. The leak is likely no where near the light or overhead consol. As mentioned above, check the roof rack holes or, if you have one of those shark fin antennas, check around that also.
  4. Dec 12, 2012 at 12:06 PM
    kryten
    Canada
    No, don't have a roof rack. I will inspect it more tonight after work.
    I don't have a shark fin antenna on my truck. Well, I will take a closer look as you guys suggested.
  5. Dec 12, 2012 at 12:13 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    There was a TSB regarding condensation buildup in the overhead light but it was for access cabs only. Don't know if it relates to your issue.
  6. Dec 12, 2012 at 12:18 PM
    JustMe
    JustMe Active Member
    T-SB-0387-08 Rev2: '05-'11 Tacoma: Water Condensation Dripping From Headliner
  7. Dec 12, 2012 at 12:21 PM
    Pugga
    Massachusetts
    Even if you don't have a roof rack, the double cabs all have threaded nuts built into the roof to accept the OEM roof rack. They are located under the plastic strips on the roof. The third brake light is also another area where you could get water intrusion.
  8. Dec 12, 2012 at 1:37 PM
    kryten
    Canada
    I forgot about third brake light.
    Thanks for the TSB guys, I have an 07 so way out of warranty, but it may still help me resolve this just not for free.
    Is that TSB pdf available for download/viewing?
  9. Dec 12, 2012 at 1:38 PM
    Pugga
    Massachusetts
  10. Dec 12, 2012 at 1:50 PM
    kryten
    Canada
  11. Mar 4, 2014 at 7:07 AM
    nevenelestate
    nevenelestate Well-Known Member
    Andrew
    Southern MD
    12 Tacoma V6 4X4 SR5
    Stock
    Anyone having this issue on a '12+? My 2012 Access started dripping this morning, it has happened before, but I keep forgetting to look into it.
  12. Mar 4, 2014 at 7:08 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    I took my '11 DC in for water dripping from the 'oh shit' handle on the driverside.
    Dealer said they couldn't 'recreate the problem' and therefor there was no problem.
    Good luck with a resolution!
  13. Mar 4, 2014 at 7:11 AM
    nevenelestate
    Andrew
    Southern MD
    Stock
    That's what I'm worried about, it never happens when I am able to take it in...of course.
