water dripping on driveway passenger side after driving
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jeyx, Sep 19, 2014.
  1. Sep 19, 2014 at 4:45 PM
    Jeyx
    Jeyx [OP] New Member
    Ca.
    Tacoma 2x4
    I've always had a pool of water under the passenger side of the truck ( 1999 Tacoma 2whl ) just under where the exhaust manifold comes down from the engine. I have always wondered what this was and seem to have read somewhere that it was condensation from the a/c or something. But I hardly run the a/c. And it seems that the air vents always blow really cold air whether I have the a/c on or not. Is it possible the a/c is always running ?
    Thanks
  2. Sep 19, 2014 at 4:52 PM
    muddog67
    muddog67 Well-Known Member
    Open the hood and run your engine and see if your clutch to your compressor is turning when the AC is off then turn on your AC and look if Clutch is running . As far as the puddle under your passenger side goes , yes it is probably your ac condensation .
  3. Sep 19, 2014 at 5:16 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If you are have the defrost setting dialed in, the A/C pump will run and cause the evaporator to become cool, thus removing humidity from your cab. The humidity is turned into water and is drained to the ground on the passenger side.
    mackbolan951 likes this.
  4. Sep 20, 2014 at 5:33 AM
    Jeyx
    Ca.
    Tacoma 2x4
    Thanks for the info muddog67 and koditten ! I do have the defrost setting on ! I'll check out that AC clutch today.
    Thanks
  5. Sep 20, 2014 at 2:51 PM
    Jeyx
    Ca.
    Tacoma 2x4
    "Water dripping on driveway " update
    Yup, turned off the defrost and no puddle under the truck. And, no cold air blowing out the vents. And, as expected, the AC clutch disengaged with the defrost off. I cycled the defrost switch and watched the AC come on. Well, this changes everything. For one, I should get better gas mileage. And it won't be so cold in the cab ! Is this how it's supposed to work ?
    Thanks
  6. Sep 20, 2014 at 3:09 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    That is exactly how it is supposed to work. Defog works 1000x better with A/C working as a dehumidifier. If you ever drive a car without A/C and try to defog the window you will understand. haha
