water fuc#ed up my engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudjunkie, May 14, 2009.
  1. May 14, 2009 at 5:31 PM
    mudjunkie
    mudjunkie [OP] Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
    last night i was driving home when it started to rain i was about 20 minutes away from home well it poured rain i had to pull over for a minute any who i started to drive again and it was flooded i didnt really care cuz ita a truck so i went through it well i guess the water splashing up in the engine bay really messed things up for the most part she drives fine but every now and then when go to start off in first gear she acts like she is going to stall so i floor itt and sometimes when i go from third to fourth and try to cruise the truck acts like she is going to stall please help
  2. May 14, 2009 at 5:33 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    anything else acting up or just trying to stall?
  3. May 14, 2009 at 5:34 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    could be that the cables to and from the spark plugs are wet??
  4. May 14, 2009 at 5:44 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    she also idles real low until i turn on the ac the it purrs like a kitten i checked the wires and i dried them and used a water remover spray i also checked the distributor and the intake nothing out of the ordinary i took a plug out and turned over the engine a few times to see if water comes out and i got nothing
  5. May 14, 2009 at 5:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Could you please use some of these "." ...even if just randomly placed some where in your post....
  6. May 14, 2009 at 5:47 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    hows the ole alternator?
  7. May 14, 2009 at 5:50 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    my bad, i was using my iphone, its a lot of work to use punctuation marks. ok so, when i start my truck and place it in 1st gear as i begin "to give it gas and release the clutch" the truck wants to stall so i have to rev the rpms. also when i shift into 4th gear and try to idle at normal speed the truck feels like it wants to die.
  8. May 14, 2009 at 5:51 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    what do you mean the alternator works fine no problems there at all.
  9. May 14, 2009 at 5:54 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    chris 4x4 if anyone can figure this out its you i know it.
  10. May 14, 2009 at 5:54 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    the last time i went thru a big "puddle" my alternator gave up...truck would try to stall until it finally just crapped out...replaced the alt...everything is gravy now
  11. May 14, 2009 at 5:56 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    did i try to stall all the time or every so often because my truck only does this every couple of times.
  12. May 14, 2009 at 5:59 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    every once in awhile until it finally succeeded at stalling...then it wasnt starting back up
  13. May 14, 2009 at 6:00 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    should i test it
  14. May 14, 2009 at 6:03 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    dunno
    granted...my alt going bad also brought on other symptoms...tach didnt work...neither did the radio...or temp gauge...
    been in a lot of mud?
  15. May 14, 2009 at 6:04 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    not for months been busy just water
  16. May 14, 2009 at 6:05 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    unless someone else has a better suggestion as the cause...id prob get it tested
  17. May 14, 2009 at 6:09 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    come on chris 4x4 lol
  18. May 14, 2009 at 6:16 PM
    Griztaco
    Griztaco Well-Known Member
    ID
    TRD
    Sounds to me like you got water in your gas tank or fuel lines. If I was you, I would immediately go to the gas station and pick up some of that fuel treatment for water....couple dollars, problem fixed.
  19. May 14, 2009 at 6:18 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    great idea does walmart cary it
  20. May 14, 2009 at 6:20 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    02 4runner 04 solara
    4runner-32x11.5x15 falken rocky mt, tundra king 2.5 coilovers with taco perch, TC UCA, OME rear springs and procomp es9000's, thule roof rack.
    could a wet sensor cause this?
