water fuc#ed up my engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudjunkie, May 14, 2009.
  1. May 21, 2009 at 7:59 AM
    #41
    jasonh
    jasonh tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    lol
  2. May 21, 2009 at 2:06 PM
    #42
    mudjunkie
    mudjunkie [OP] Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
    sorry guys been trying to fix this engine still runs rough i need to replace the mass air flow sensor which wil be costly, i bought some MAF cleaner and it has helped alot and now i need to clean the throttle body to see if that helps.
  3. May 23, 2009 at 1:10 PM
    #43
    mudjunkie
    clearwater fl
    96 tacoma sx l
    ok guys its been a while i have gone through every wire on the truck no moisture i replaced the mass air flow sensor and nothing has changed. if anything i am starting to get a shutter at 40 mph. someone told me it may be my belts not catching, or the transmission.
  4. May 23, 2009 at 1:52 PM
    #44
    S1E675
    S1E675 Never enough toys
    Ohio
    04 TRD 4x4
    Personally I would take it to your mechanic/dealer and put it on the computer. It sounds like you have a bad sensor somewhere, and that will tell you what is actually wrong.
    This makes a lot of sense. As I understand it the water is immiscible in the IPA, and the IPA is immiscible in the gas. I think it is called a co-solvent or something like that. Either way, it won’t hurt to try it.
  5. May 23, 2009 at 4:16 PM
    #45
    Griztaco
    Griztaco Well-Known Member
    ID
    TRD
    You mean water in immiscible in gas, but IPA is miscible in both gas and water.
