Water heater question
Discussion in 'Garage / Workshop' started by coffeesnob, Mar 13, 2013.
  1. Mar 13, 2013 at 5:57 AM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    The pop off valve on my hot water heater seems to open a lot. It is in the garage. I have noticed every now and then a small puddle near the heater where it has gone off. This past week I noticed quite a bit more than normal. I know the valve is doing it's job but I have never had a heater pop off valve open before just curious why the pressure is building so much..Any thoughts? Thanks
  2. Mar 13, 2013 at 6:25 AM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    temp set to high on the thermostat. Or valve may have a weak spring or bad seal.
  3. Mar 13, 2013 at 6:56 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Check water pressure. 80 psi or above needs a prv here. Change out t&p,install expansion tank.
  4. Mar 13, 2013 at 7:00 AM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    X2^^^^
  5. Mar 13, 2013 at 9:01 AM
    coffeesnob
    VA
    Thanks all....I don't have a gage to check water pressure, but the pressure here is better than anywhere else I have ever lived I bet that is what it is.
  6. Mar 13, 2013 at 9:02 AM
    coffeesnob
    VA
    Well another question would it be ok just to leave it alone or am I looking for more trouble down the road..
  7. Mar 13, 2013 at 12:12 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    This problem needs to be fixed, especially with gas water heater.
  8. Mar 13, 2013 at 3:18 PM
    coffeesnob
    VA
    I am all electric but advice well taken.
  9. Mar 13, 2013 at 3:24 PM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    Replace prv with one of correct rating and add expansion tank if not there...
  10. Mar 15, 2013 at 4:22 AM
    Bistineau
    Bistineau Well-Known Member
    Bossier Parish La.
    2013 Prerunner SR5
    Para-bolic mirrors on the outside rearveiws.
    It's best to replace it. They are not expensive and are easy to do. Just use some teflon tape or other thread sealer when you install it. Leaving it as is will cost you more in water bills than replacing it. Sometimes the spring can get weak from age. If the new one leaks too, then a pressure regulator may need to be installed to reduce the pressure to the tank if the temperature is set correctly(should be no more than 120* F.)
  11. Mar 15, 2013 at 4:29 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    this ^^ water heater is done, get a new one
