Water Heating Question: House Related - Help Plz
Discussion in 'Garage / Workshop' started by 1BlkT, Apr 30, 2010.
  1. Apr 30, 2010 at 2:03 PM
    1BlkT
    1BlkT [OP] Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    Does anyone know how long it would take to get hot water when the water heater is 80 feet away going through 3/4'' pipe at 1.2 gallons per minute?
    Someone asked me and I had no clue so I figured some of you smart guys would know what formula to use or how long it would take.
    Thanks for your help!
  2. Apr 30, 2010 at 2:50 PM
    1BlkT
    Ty
    90603
    Anyone?
  3. Apr 30, 2010 at 3:03 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    1 foot of 3/4 pipe holds 3.5 oz. So you get about 1 gallon of water in 36 feet of pipe. 80 feet of pipe holds 2.2 gallons. So it should be just under 2 minutes. (I think)
  4. Apr 30, 2010 at 3:28 PM
    1BlkT
    Ty
    90603
    Rep Sent! Thanks for your help. That gives me a better idea now.
  5. Apr 30, 2010 at 4:13 PM
    oldtacomaguy
    Dave
    SE Conn.
  6. Apr 30, 2010 at 4:54 PM
    spp
    spp OC, Kalifornia
    OC California
    1.2 gpm from a 3/4 pipe?
    Seems way low. What is the water pressure like?
  7. Apr 30, 2010 at 5:25 PM
    1BlkT
    Ty
    90603
    The water pressure is 65 lbs psi, but with new Cali Laws and the faucet being a low flow that's why it's only flowing 1.2gpm out.
  8. May 2, 2010 at 11:21 AM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    Alright, so riddle me this... I'd like to know how much water ended up under my house when the pipe burst inside the wall. It took me roughly 45 minutes to get the water turned off at the street (partly because I am an idiot). Not sure what the actually water pressure is, but would assume around 65 PSI and there was virtually no restriction in the 3/4" pipe.
    What is the typically rate of flow in a 3/4" domestic water line?
  9. May 2, 2010 at 11:48 AM
    LazyNavyTaco
    LazyNavyTaco Well-Known Member
    Jared
    Virginia Beach, VA
    06' Silver, DC, TRD Sport
    DNX-5120 head unit, 2-JL ZR650-Csi component sets, JL 500/1v2 amp, 17x9 Ultra Baron's, LT285/70R-17 Goodyear Wrangler DuraTrac D's, ShrockWorks front bumper with skid plate and light bar
    well i was a licensed journeyman plumber in Mississippi before i joined the navy and in my experience with low flow faucets getting more water out of them is simple. if you unscrew the cap at the end of the faucet that holds the screen you can remove the piece that restricts the water flow. but if your not happy with the time it takes you to get hot water to your faucet and you live in cali you might want to try the in line water heaters that dont actually make hot water until the water passes through them. not only are they vastly more efficient but here in Virginia im pretty sure they give you a break on your taxes for having them... just an idea....
