Water holder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Waasheem, Dec 6, 2021.
  1. Dec 6, 2021 at 6:00 PM
    Waasheem
    Waasheem [OP] The catholic radio bear
    Waasheem
    2007 xrunner
    I always hated having to go to the big box store to get cases of water. Mainly because they would slide partially forward from braking, then I’d have to climb into the bed to slide them back to unload. I’ve tried going backwards then slamming on the brakes, it sorta works but it freaks my neighbors out.
    I thought of trying a bed mat. The problem is if it isn’t bolted down, locked up, it’ll get stolen. Someone stole my front door mat. Someone tried to steal a garden hose running along side my house out to the front under the gate. It goes to a pump in a low spot in my patio for heavy rain.
    So this is what I came up with. I got creative with some 3/16 nylon rope, a couple s hooks, and one of those nite ize cam jam tie downs. Every cut end on the rope I melted with a soldering torch to prevent fraying. I’ll probably make some adjustments. The rope rides a little high on the bottles.
    JimIowa, jeminyned, CusterFan and 3 others like this.
  2. Dec 6, 2021 at 6:12 PM
    PlumpPossum
    PlumpPossum Founder
    Caleb
    GSP SC
    2021 TRDORMT | 1986 PICKUP
    Hell yea
  3. Dec 6, 2021 at 6:13 PM
    tcjacado
    tcjacado Well-Known Member
    You need a bed mat
    b_r_o, essjay, uurx and 3 others like this.
  4. Dec 6, 2021 at 6:17 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    A factory tailgate extender in reverse is exactly what you need, although it costs more than your solution.
    6 gearT444E likes this.
  5. Dec 6, 2021 at 6:28 PM
    Waasheem
    Waasheem
    2007 xrunner
    I thought those were meant to be used like this.
    RedDemolisher, Dm93 and 2015WhiteOR like this.
  6. Dec 6, 2021 at 6:47 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Got one of these for sale
    Can’t see shipping though. Little heavy and it is OEM
  7. Dec 6, 2021 at 7:06 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  8. Dec 7, 2021 at 12:50 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Tap water man, get a conditioning system.
    Knute, Reggie4x4, plurpimpin and 3 others like this.
  9. Dec 7, 2021 at 1:11 AM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Invest in a Britta and a reusable water bottle.
    Reggie4x4, TartanEagle and jwctaco like this.
  10. Dec 7, 2021 at 1:14 AM
    Redfive11
    Redfive11 Well-Known Member
    La Mirada, CA
    2012 PreRunner
    FOX 2.5 EXTENDED TRAVEL w RESI /DSC CAMBURG UCA PELFREYBILT HYBRID FRONT BUMPER
    So you used rope? Inventive.
  11. Dec 7, 2021 at 5:39 AM
    tcjacado
    Cutting edge stuff :fistbump:
  12. Dec 7, 2021 at 5:42 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Not just regular rope, but rope with branded ends to prevent the fraying. It's the small details you know.
  13. Dec 7, 2021 at 7:05 AM
    TerraNerva
    TerraNerva Well-Known Member
    Chip
    Central Arkansas
    Ummm....Tundra
    I have one and use one. Works great.
  14. Dec 7, 2021 at 10:35 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Bed mat is a necessity IMO. One bolt in the front center drain hole through the mat and you are good to go.
  15. Dec 7, 2021 at 10:48 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    3/4 plywood chanel and 3/4 pine wood . Channel bolted using bed box bolts . Pinewood needs to be sanded on end till slides in easy .
  16. Dec 7, 2021 at 11:30 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    ^This. And a SodaStream. I refuse to use single use plastic bottled water these days.
  17. Dec 7, 2021 at 11:38 AM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    My first instinct was to make fun of this, but hey, what good would that do?
    As others have suggested, cargo bar is the most affordable option and will do exactly what you need it to. I use my bed extender when I really need to, but it probably is not worth the investment here when a $20 cargo bar will do.
  18. Dec 7, 2021 at 4:19 PM
    riverrat958
    riverrat958 Well-Known Member
    keith
    upstate ny
    2015 base crew cab tacoma
    camera source backup, camera seat covers,intermittent wiper arm
    I use a 2x4 across and 2 2x4 legs to the tailgate
  19. Dec 7, 2021 at 4:29 PM
    HansLanda
    HansLanda Well-Known Member
    Buying bottled water lol
    clenkeit likes this.
  20. Dec 7, 2021 at 5:44 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
