Water In Backup Camera- FIXED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PzTank, Oct 25, 2018.
  1. Oct 25, 2018 at 5:35 AM
    PzTank
    PzTank [OP] Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Did a search and didn’t find this covered..
    Truck is a ‘15 AC SR5 4X4
    After it rains, I have water sloshing around in my backup camera.
    It’s like I’m looking through a fishbowl for several days afterwards until it dries out.
    Anyone else experience this, know of the fix? I’m thinking its a gasket but I couldn’t find anything on the web.
    Thanks.
  2. Oct 25, 2018 at 6:28 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    i only see water on it, i go back and wipe it off and it solves my problem, not sure for you
  3. Oct 25, 2018 at 6:51 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Try putting a little silicone around the camera.
    Biscuits and PzTank[OP] like this.
  4. Oct 25, 2018 at 7:07 AM
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Pull the tailgate handle assembly out of the tailgate. Remove the plastic splash guard and put it in correctly... Put it all back together and it should be fine.
  5. Oct 25, 2018 at 8:10 AM
    PzTank
    Above the Notches
    Yeah, it’s definitely inside the camera, like I said, sloshing around, back and forth...
  6. Oct 25, 2018 at 8:12 AM
    PzTank
    Above the Notches
    I’ll give it a shot. Thanks. Any tricks or tips to this? Small tabs to break??
    Stryker420[QUOTED] likes this.
  7. Oct 25, 2018 at 8:13 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    You still under the 3yr 36k ?
  8. Oct 25, 2018 at 11:55 AM
    PzTank
    Above the Notches
    No, I’m at 58K now..Good thing to consider, thanks!
  9. Oct 25, 2018 at 1:17 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    This is because you didn’t replace the backup camera fluid. Dude, that is second most important to blinker fluid replacement
  10. Oct 25, 2018 at 1:19 PM
    R490
    R490 Well-Known Member
    Upgrayedd
    VA/PA
    Free aquarium..... hello
  11. Oct 25, 2018 at 3:03 PM
    PzTank
    Above the Notches
    Yeah, I was thinking about stuffing a tiny plastic shark in there....
  12. Oct 25, 2018 at 3:50 PM
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Do you have a EZ lok locking tailgate handle?
  13. Oct 25, 2018 at 4:06 PM
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Yeah not everybody follows the services manual intervals...
    PzTank[OP] likes this.
  14. Oct 25, 2018 at 4:07 PM
    PzTank
    Above the Notches
    Nope.
  15. Oct 25, 2018 at 4:10 PM
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Ok well. If you did. You would be a master tailgate dissasembler. Well just drop the tailgate. Open beer and take off access plate. Then remove linkage rods. Then take off 2 nuts holding on handle. Camera cable in there so be careful. Take out camera and do a detailed visual inspection. (DVI)
    PzTank[QUOTED][OP] likes this.
  16. Oct 26, 2018 at 3:55 AM
    PzTank
    Above the Notches
    Thanks @Stryker420. I'll do it over the weekend and report back here. If I miss the fishbowl effect, I'll unseal it this Spring, fill w water and put the tiny shark in for the summer..
  17. Oct 26, 2018 at 6:50 AM
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Or you could do a dash aquarium like pimp my ride...
  18. Oct 26, 2018 at 7:38 AM
    PzTank
    Above the Notches
    I spill enough coffee in my truck as it is now, can’t imagine managing an aquarium..
  19. Nov 3, 2018 at 1:16 PM
    PzTank
    Above the Notches
    Didn't need to pull the handle assembly completely. Removed the interior panel from the tailgate- #30 Torx all around. The camera comes out by itself with 2 10 mm bolts. It's nice that camera protrudes from the base out the hole where you can see the camera besides the handle to drop the tailgate. Ran a bead of silicone around the camera base and sides and put it all back together. Raining now so I went out to check it and it looks dry as a bone. Can't see the silicone - white was all I had....Good stuff. Thanks @Stryker420
  20. Nov 3, 2018 at 7:09 PM
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Yeah no worries. I'm glad I could help.
