Water in differentials?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Greidtaco, Jan 13, 2016.
  1. Jan 13, 2016 at 7:35 PM
    Greidtaco
    Greidtaco [OP] Member
    Tacoma
    Hello everyone! I recently bought a 2015 Toyota Tacoma trd off-road. I went "off-roading" which was not even that off-road. I went through a small pond that was up to the middle of my rim. I read later that if you get water in your differentials it can cause vibration. I just drove down to Florida from pennsylvania. I feel like I can feel vibrations in my pedals but I'm not sure. I took it to a dealer and they said it might be my tires. I'm coming in here because I was hoping someone could help me out possibly describe what the vibrations are like and where I would feel them. I'm hoping I'm,just paranoid. The vibrations aren't strong at all and I feel them most at slow speed 1-10 mph when I'm turning. Any help would be great.
  2. Jan 13, 2016 at 10:41 PM
    Greidtaco
    Tacoma
    Thank you. Its been bugging me really bad. You don't think there are any serious issues though right?
  3. Jan 13, 2016 at 10:45 PM
    Greidtaco
    Tacoma
    Thank you both for responding.
    DoorDing likes this.
  4. Jan 13, 2016 at 10:45 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    It's probably the tires
  5. Jan 14, 2016 at 3:43 AM
    Tarzan13
    Tarzan13 Well-Known Member
    Keith
    Longmont, CO
    2015 DC TRD Off-road
    I used to off road my old CJ7 through creeks, mud bogs, and ponds. I changed my diff oil once a month in the summers of my youth. It looked like marshmallow fluff when it came out and the diffs were never my problem on that old thing. :)
  6. Jan 14, 2016 at 6:25 AM
    Pigpen
    Dan
    Northwest Montana
    Extending the diff breather is a "hero" mod. It's very easy (not technical) and doesn't take long to do, plus it's one of the mods that really does help out your truck. If you're no mechanic, it makes you feel like one!
    Tarzan13 likes this.
