Water in drivers side door
Discussion in 'North East' started by Skell, Oct 27, 2017.
  1. Oct 27, 2017 at 12:27 PM
    Skell
    Skell [OP] KORE
    Tony
    NE PA
    2015 DCSB, grey
    custom car grill, KORE sliders, light bar, KORE bed bars w/ tire and high lift mount. MOBTOWN front IFS skid.
    After my last bit of wheeling, I noticed a sloshing sound coming from the drivers side door. There is a little rubber plug at the bottom back corner of the door. I reefed that out and moved the door around and some little bit of water splashed out. Is there another spot i can pull a plug or should i break out the drill?
    Thanks,
    -Tony
  2. Oct 27, 2017 at 12:47 PM
    Clearwater Bill
    Billy
    Largo Florida
    There should be drain holes already in the bottom of the door? Water is supposed to flow out that gets in.
    If you can find them (3 or 4?) you might be able to clear them with something like a stiff wire. You can also use a small tool to gently pry the opening to be a bit larger.
    That will help you clear the hole and potentially keep it from re clogging as easily.
  3. Oct 27, 2017 at 12:53 PM
    Skell
    Skell [OP] KORE
    Tony
    NE PA
    2015 DCSB, grey
    I have a look, I may or may not have had mud over the the front headlights..... perhaps that has plugged something up?
    Bastek likes this.
  4. Oct 27, 2017 at 7:23 PM
    Skell
    Skell [OP] KORE
    Tony
    NE PA
    2015 DCSB, grey
    Got it drained!
    Bastek likes this.
  5. Oct 28, 2017 at 4:08 AM
    Clearwater Bill
    Billy
    Largo Florida
    Posting 'how' for the good of future readers of this thread would be helpful.
    tomwil and Bastek like this.
  6. Oct 30, 2017 at 6:18 AM
    Skell
    Skell [OP] KORE
    Tony
    NE PA
    2015 DCSB, grey
    Along the length if the door, If you run your fingertips along the bottom, you'll feel three fairly prominent rubber grommets, with oval holes. I took my truck key tip and wiggled it about some in them and water started draining immediately.
  7. Oct 30, 2017 at 6:21 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Another reason to avoid water and mud.
    ChadsPride likes this.
  8. Oct 30, 2017 at 6:22 AM
    Skell
    Skell [OP] KORE
    Tony
    NE PA
    2015 DCSB, grey
    Where is the fun in that!
  9. Oct 30, 2017 at 6:24 AM
    JayRolla
    Colorado Springs
    I did all that when I was 16-21. Now I rock crawl. The amount of time in cleaning is enough to avoid it.
    Also water and mud in diffs, wheel bearing, brakes, suspension, frames, starters, ect takes its toll on your rig.
  10. Oct 30, 2017 at 7:07 AM
    Skell
    Skell [OP] KORE
    Tony
    NE PA
    2015 DCSB, grey
    My skids are getting ordered this week!
    JayRolla[QUOTED] likes this.
