Water in gas tank
Discussion in '3rd Gen. Tacomas (2016-2023)' started by overlandtaco77, Oct 1, 2023.
  1. Oct 1, 2023 at 9:05 AM
    overlandtaco77
    overlandtaco77 [OP] Member
    Tacoma
    What’s the best way to drain bad gas from my 3rd gen taco?
    I know I can’t siphon it from the filler neck and I know that I can’t jump the fuel pump relay. So is my only option to have a shop with a Scan tool turn the pump on to drain the tank?
  2. Oct 1, 2023 at 9:52 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    You could try gas line antifreeze, depending on how bad it is. It allows the water to break down and pass through the system and burn it off. Once you have run through a couple of clean tanks with fuel antifreeze, change the filter.
  3. Oct 1, 2023 at 10:10 AM
    Tallgrass05
    Tallgrass05 Well-Known Member
    How do you know it is bad gas?
    Tacosha and RedWings44 like this.
  4. Oct 1, 2023 at 10:18 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    use star tron. we get a lot of water contaminated gas in my area.
  5. Oct 1, 2023 at 10:32 AM
    overlandtaco77
    Tacoma
    I have tried 2 bottles of heet and the filter is in the tank so I’d have to drop a full tank
  6. Oct 1, 2023 at 10:39 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I'm also wondering how you know you have water in your fuel tank.
  7. Oct 1, 2023 at 10:49 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    heet is garbage. try startron. or you can drain your tank.
  8. Oct 1, 2023 at 10:51 AM
    overlandtaco77
    Tacoma
    Thanks for the starteon recs I will try that. Any other ideas on how to drain the tank without an expensive scan tool?
  9. Oct 1, 2023 at 10:53 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    just try to burn as much fuel as possible before filling up again. maybe get a gas container and drive until it says range:0. or just drive it until it dies, not great for the fuel pump but i don't think running out of gas once is going to kill it.
  10. Oct 1, 2023 at 10:55 AM
    overlandtaco77
    Tacoma
    Sorry if I didn’t mention it, but it doesn’t start :(
  11. Oct 1, 2023 at 10:56 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    do you have any codes? how do you know it's water in your fuel? i've never had so much water in my fuel that truck wouldn't start.
  12. Oct 1, 2023 at 10:59 AM
    overlandtaco77
    Tacoma
    While I appreciate the troubleshooting help, what I’m really asking for is technical help draining the fuel tank.
  13. Oct 1, 2023 at 11:03 AM
    Horseshoez
    Dale
    Maryland
    Unless there is something you're not telling us, the odds of there being so much fuel in your tank to prevent the engine from starting are pretty slim.
  14. Oct 1, 2023 at 11:06 AM
    overlandtaco77
    Tacoma
    The great flood came. How do I drain my fuel tank?
  15. Oct 1, 2023 at 11:09 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Do 3rd gen fuel pumps not kick on when the key is in the ON position? If anything pull the bed, that'll give you access to the tank. From there you can siphon most of it out from a disconnected fuel hose I'd think.
  16. Oct 1, 2023 at 11:16 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  17. Oct 1, 2023 at 1:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    If the filler neck was submerged and the cap leaked, you surely had water in cab and possible ECU damage?
    RedWings44 likes this.
  18. Oct 1, 2023 at 1:10 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Drill a hole in the tank, drain it, seal the hole. Quick and simple.
  19. Oct 1, 2023 at 1:29 PM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    If you bought contaminated gas wouldn’t the station be responsible for the repairs? That is the way it works here.
  20. Oct 1, 2023 at 1:42 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The fuel tank on modern automobiles is sealed quite well to prevent greenhouse emissions. There are a ton of other reasons high water might have affected your engine negatively. Unless you have reason to believe there is water in your gas tank, I would start with other potential causes.
    In any case, I suspect the best way to drain your gas tank is to remove it, turn it upside down, and let gravity do its work. Some sort of pump might work too, but I think there is a screen in the filter tube to present foreign material and siphoning tubes.
