Water in my fog lights with brand new HIDs!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hunter500ky, Dec 30, 2010.
  1. Dec 30, 2010 at 6:16 PM
    Hunter500ky
    Hunter500ky [OP] Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Damnit!!!!! :mad::mad:
    I noticed there appeared to be water on my fog light, went to wipe it off..... its on the inside ahhhhh!!!!
    I have not went through deep water or anything, just washed it the other day, it has been raining I have hit a few puddles (in the street like pot holes)
    So now my HID on driver side is lightly flickering.......
    Am I screwed?
  2. Dec 30, 2010 at 6:18 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    Na.. Just take it out open it up or take the bulp out and let it dry. Then when its dry put some silicone around it and put it back in.
  3. Dec 30, 2010 at 6:19 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You can also throw a silica gel packet in the housing to soak up and moisture and prevent fogging.
  4. Dec 30, 2010 at 6:19 PM
    l_prettyman
    l_prettyman Well-Known Member
    Logan
    Easton Shore Maryland
    06 4x4 SR5
    12% tint, Leer cap, Pioneer Avh3100DVD headunit, Kinetik 2000 battery, Memphis pr1.1000 amp, Pioneer subwoofer(not sure what kind), Back-up Camera, PA/CB system
    you could try taking the light out and whipping it with an alcohol pad and using a clean microfiber afterwards. and let the light dry out. oh also make sure the seals on the lights are good and tight when you put the light back in.
  5. Dec 30, 2010 at 6:21 PM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    OK cool thanks guys!
    The light was in TIGHT!!!
    So I'll end up silicone around it I supposed, I thought about that the night I did it but I didn't know.
    Thanks guys whew I was like damnit!
  6. Dec 30, 2010 at 6:22 PM
    Blackshirts
    TX
    09 PreRunner
    Stuff
    Smallest hole will let water in.. Even if it is tight.
    I know the frustration. But its all apart of Modin
  7. Dec 30, 2010 at 6:24 PM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Ok so tomorrow I am going to the lights ok, clean them with a alcohol pad, not touching it with my fingers. Then cleaning the housing out, the putting the light back in and silicone around the outside of the rear housing correct?
    Thanks again whew Im so happy thought I just killed 100$ lol
  8. Dec 30, 2010 at 9:11 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Do your fogs have these holes?
  9. Dec 30, 2010 at 9:52 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    You could also try that rain-ex product that prevents fogging up. Just a thought.
  10. Dec 31, 2010 at 7:30 AM
    l_prettyman
    Logan
    06 4x4 SR5
    true true
