water in my headlight
Discussion in 'Lighting' started by eschonle, Apr 5, 2010.
  1. Apr 5, 2010 at 5:15 PM
    eschonle
    eschonle [OP] Well-Known Member
    eric
    Seattle, WA
    2006 V6 SR5 4x4
    TRD Cat back Exhaust, Leer Shell, BHLM, Satoshi Grill
    I noticed that my passenger side head light assembly is fogging up after i did my own BHLM. I thought i was careful enough and used a copious amount of silicone sealant around the edge but alas, still water got in.
    any ideas on what i should do?
  2. Apr 5, 2010 at 5:18 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Is the rubber boot around the headlight completely on? Did you add sealant before or after you put the halves together? Are the caps for the vents back in?
    Try using 3M Windo-Weld next time.
  3. Apr 5, 2010 at 7:03 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    When I got water in one of my gauges on my boat I used a hair dryer and it dried right up just don't hold it there too long. As far as long term you may have to pull it apart and do it again if it's not the boot.
