Water in my intake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TmecTaco79, Feb 20, 2011.
  1. Feb 20, 2011 at 2:04 AM
    TmecTaco79
    TmecTaco79 [OP] Well-Known Member
    Adam
    Escondido,CA
    06 TRD PreRunner 4x2
    Bilstein 5100's, 33" BFG AT, Magnaflow
    So at about 9:45 tonight I went to get some food. There happened to be a water puddle and I drove through it. When I reached the other side my truck stalled out and died. Got it towed home and pulled the intake off and found water. Pulled the spark plugs out and found water on three spark plugs.
    So bumbed right now:( I'm not sure what to do. I have a warranty still. I was thinking about cleaning the cylinders out and taking it to the dealership.
    Anyone have any thoughts?
  2. Feb 20, 2011 at 2:17 AM
    ViperJay
    ViperJay These are the voyages...
    El Paso, TX
    05 Radiant Red DCLB Sport 4x4
    URD CAI, DTLT Headers, Vibrant Ultra Quiet Resonator, Aero 2540i muffler, NST Pulleys, URD MAF Calibrator, Icon 2.5 Coilovers , Bilstein 5100s in rear with All Pro 3" Leaf pack, Total Chaos UCAs, 2 Kicker 12" CVT Subwoofers w/Kicker ZX350.2 Amp, JVC KD-AVX77 stereo, ARE Camper Shell, 1 20" LED bar and 2 7" LED bars in front, 4 KC 6" HID Slimlites mounted on Bajarack roof rack, sliders, Cobra 29 XLR CB Radio, Icom IC-207H UHF/VHF Radio, Bed Lighting, Fog light mod, Projector Retrofit Headlights HID 5000k, HID fog lights 4300k, BHLM, LED taillights and turn signals, Glassworks front fenders, Blue Sea Fuse Box, Mil-Spec Battery Terminals, Odyssey PC2150 battery, Satoshi Grill, All-Pro Front Bumper
    You engine could be hydrolocked, I think I remember seeing a solution where you could take off all the spark plugs and rotate the engine using the starter and the water would come out of the engine.
    But that's just what I have read online. Hopefully someone else chimes in with some better info.
  3. Feb 20, 2011 at 3:00 AM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    how deep was the water?
    i'm not quite sure what happened ive had my truck in pretty deep without stalling.
    was the water in you intake past the filter or before it? hydro-lock is a posibility and the solution is as mentioned above.
  4. Feb 20, 2011 at 3:07 AM
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    http://cgi.ebay.com/ebaymotors/05-06-07-08-09-10-TOYOTA-TACOMA-ENGINE-4-0L-6-CYL-/110637750237?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AToyota%7CModel%3ATacoma%7CYear%3A2010&hash=item19c28617dd
    hydrolocked engine, bent, damaged, or broken push rods, warranty won't cover it, if you fight the warranty claim you can claim poor engineering with the air intake mounted too low and its also designed as an off road truck and should be designed to take that type of abuse, Toyota will come back and claim the size of the water puddle was excessive, and or they don't know how deep the water puddle is and there is no set limit and stuff like that, and Toyota will also find some type of write up in the operators manual about driving thru water.
    you can make a claim with your insurance co and ask them to investagate why the deep water was there and maybe they can file a claim against the government road maintenance claiming their screw up caused that water puddle, or you can get an attorney, but he will cost you big money and with the money you give him can maybe pay for a used engine.
    good luck, its going to take a lot of work and rejections on your end to make it happen.
  5. Feb 20, 2011 at 5:10 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    hopefully is just wet...had a BMW motorcycle and the coil case cracked, leaving me stuck in mist one day:)
    Pull the plugs, turn the engine over and see what happens.
    Howard
  6. Feb 20, 2011 at 7:56 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    pull the plugs, give it a day or two to dry. Turn the engine over
  7. Feb 20, 2011 at 9:21 AM
    TmecTaco79
    Adam
    Escondido,CA
    The puddle was like 8" deep and the water wast past the intake:( I took out the plugs and found water in three cylinders. Would you recommend cranking the engine over by hand or with the starter?
  8. Feb 20, 2011 at 10:07 AM
    TmecTaco79
    Adam
    Escondido,CA
    Cranked the engine over by hand with all the plugs out and it get stuck in one spot. I'm thinking I bent a pushrod:(:(
  9. Feb 20, 2011 at 10:11 AM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
  10. Feb 20, 2011 at 10:11 AM
    rhodehard09
    tampa, fl
    take all the plugs out(if you haven't already) and turn it over with the starter. at first just for a second and listen for any horrible noises coming from the engine. if no horrible noises, crank it over for maybe 3-4 seconds then leave it alone for an hour. put the plugs back in and try it out...if it still doesn't start try spraying some maf sensor cleaner on the maf sensor let it sit for a minute and try again...if you do hear horrible noises when you first crank it, there is serious internal damage.
  11. Feb 20, 2011 at 10:12 AM
    eight3one_offroad
    Richard
    I will thank myself for buying a Filter wrap on my AEM brute force!
  12. Feb 20, 2011 at 10:14 AM
    TmecTaco79
    Adam
    Escondido,CA
    Another thing too, I have the TRD CAI. But I still have my stock intake. Should I swap out the CAI and then take it to the dealership? Or just leave on the CAI and say I was just driving around town and it stalled on me?
  13. Feb 20, 2011 at 10:16 AM
    rhodehard09
    tampa, fl
    shit you wrote this while i was responding....well unfortunately you may have bent a connecting rod(not pushrod) time to take it to a mechanic....all conecting rods will have to be checked and hopefully you didn't hurt the cylinder wall..
    just a question for ya, were you running a stock intake?
  14. Feb 20, 2011 at 10:16 AM
    TmecTaco79
    Adam
    Escondido,CA
    That's what I meant instead of pushrod lol. Kinda hard to focus on things right now.
  15. Feb 20, 2011 at 10:17 AM
    rhodehard09
    tampa, fl
    damn you keep answering my questions befor i get done asking....
  16. Feb 20, 2011 at 10:18 AM
    TmecTaco79
    Adam
    Escondido,CA
    No I have the TRD CAI. but I have the stock one in my garage.
  17. Feb 20, 2011 at 10:23 AM
    TmecTaco79
    Adam
    Escondido,CA
    Do you think I should leave the TRD CAI on and take it too the dealership or put the stock one back on since it's still under warranty?
  18. Feb 20, 2011 at 10:24 AM
    TmecTaco79
    Adam
    Escondido,CA
    Probably like 6 to 8 inches. And it was in a parking lot lol. Late night cravings get you into trouble.
  19. Feb 20, 2011 at 10:25 AM
    rhodehard09
    tampa, fl
    i guess im just lucky or the stock intake saved my ass:
    Alexely999 likes this.
  20. Feb 20, 2011 at 10:28 AM
    TmecTaco79
    Adam
    Escondido,CA
    Ya that's what I was thinking:( worst part is I'm getting laid off this coming up Wednesday. F my life right now.
