water in oil pan
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazyoldmna, Jul 1, 2014.
  1. Jul 1, 2014 at 3:51 PM
    crazyoldmna
    crazyoldmna [OP] New Member
    ky
    98tacoma
    water pump locked up has water in oil pan.heads ck ok ,head gaskets looked ok but how did the water get in oil.
  2. Jul 1, 2014 at 3:58 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    copied from mobil 1 site
    Water can get into the oil two ways. You generally don't have to worry about one of the ways if you drive your car enough to burn off the water during normal driving. This drives off the moisture that simply comes from your engine breathing when it is not being used (cold air enters a hot engine and water condenses) and from combustion by-products. The second more destructive route is through a coolant leak due to a bad gasket, an engine crack, etc. This amount of moisture is generally going to cause serious engine issues including loss of power, oil sludging, etc. Consult your mechanic when in doubt.
  3. Jul 1, 2014 at 4:09 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Send a sample to blackstone for analysis.
