Water in passenger door
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TSmalls89, May 6, 2013.
  1. May 6, 2013 at 12:26 PM
    TSmalls89
    TSmalls89 [OP] Technologically Advanced Redneck
    Tyler
    Merrimack NH
    2022 Tacoma TRD Offroad
    So I was replacing the speakers in the passenger side door and I noticed a damn good amount of moisture behind the speaker. Dried it out as best as i could, slapped the door back together and didn't think about it.
    Recently opened the passenger door and water slightly dripping from the door itself...... not sure what to think of this.... any ideas?
  2. May 6, 2013 at 12:29 PM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    Door seal leak? Dry it out and put the hose the outside and see if any water is running inside.
  3. May 6, 2013 at 12:29 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Rain gets into the door, past the window seals. It's normal, but excessive amounts points toward plugged drains, and worn/damaged seals. Look at the bottom of the door. If the slit drains are plugged, clean them. Inspect the window seals for damage and objects. Replace as necessary.
  4. May 6, 2013 at 12:30 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Make sure the drains are open and not plugged up with shit
  5. May 6, 2013 at 12:33 PM
    BostonBilly
    Easton
    Damn it I have to type faster.:eek:
  6. May 6, 2013 at 12:36 PM
    TSmalls89
    Tyler
    Merrimack NH
    1 month old truck, so i wouldn't expect that. Will definitely take a look though.
  7. May 6, 2013 at 12:39 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Lol... I didn't even look at the age of your truck. All the bases were covered though. Do the hose test. Make them replace the seals if it fills the door up. Heavy rain shouldn't flood the truck via the door.
  8. May 6, 2013 at 1:40 PM
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    Theres drain plugs in the door where the speakers are?
  9. May 6, 2013 at 5:42 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Yes, there are slit drains in all car doors, where the speakers are. If junk gets past the seal, it can plug them.
  10. May 6, 2013 at 5:50 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Maybe too much seam sealer from the factory clogging the drain.
    Shine a light where the drains are and see if you can see the light with the window down while looking down inside the door.
    If its clear its just normal.
    Did it rain that day or the day prior, did you wash your truck?
    Without driving moisture will sit in there unless evaporated by the sun heating the door or air movement from driving.
  11. May 6, 2013 at 6:02 PM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    The age of the vehicle really doesn't matter unless it's freash off the assembly line.
    Some vehicles sit on dealer lots for months before they are sold. If there are a lot of trees in the area the weep holes can get filled quickly, even on new vehicle.
