Water in passenger floor board
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1bronco47, Nov 11, 2023.
  1. Nov 11, 2023 at 12:57 PM
    1bronco47
    1bronco47 [OP] Member
    2005 White Double Cab Long Bed 4x4 Tacoma
    Hello!
    This is one of my first posts here so if i am missing another post the explains it more my apologies. I am wondering if anyone has any suggestions on what could be the cause? I have already had my AC drain lines cleared, and i do not have a sun roof. I notice that it usually only happens after a hard rain. I would also mention that my cabin air filter is alway bone dry. One test that i did was to douse the truck with a hose and i noticed that water was pooling at the base of the windshield. I feel like that is connected. But i am not totally sure how to solve it. Any suggestions would be really helpful and if someone already answered this somewhere else a link would be good too.
    Thanks!
  2. Nov 11, 2023 at 2:13 PM
    robson1015
    robson1015 Well-Known Member
    Bob
    New Concord, Ohio
    2009 base tacoma- regular cab- 5 speed
    Mine was rear window seal and 3rd brake light. I siliconed around the 3rd brake light and where the window seal was broken.
    1bronco47[OP] likes this.
  3. Nov 11, 2023 at 2:18 PM
    Odlcjro01
    Odlcjro01 Well-Known Member
    Lee
    Rhode Island
    2021 Tacoma MGM DBC SR5
    LT265/75R16 tire, side steps
    We had a Toyota Matrix that the sun roof drain lines clogged. This caused water to pool in the passenger floor boards.
  4. Nov 11, 2023 at 2:21 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I had a sunroof drain kinked in my former Nissan Altima, I installed an elbow and fixed the problem.
  5. Nov 11, 2023 at 2:54 PM
    1bronco47
    Thanks for the replies. I should mention that i do not have a sun roof so that isnt it. But i definitely havent checked the third brake light and window. Would your rear floor get wet also? Where was the water actually coming in your cab? Behind the rear seats?
  6. Nov 11, 2023 at 3:38 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My 07 does it on very rare occasions, 1 or 2 times a year. Always on the front passenger side. I have rubber floor mats and what little water comes forms a puddle that is easy to get out and nothing else seems to get wet. It does it so rarely I haven't been able to determine exactly where it is coming from. It seems to be only during a HEAVY rain when parked nose up but I'm not even sure about that. Since it is such a minor inconvenience, I don't worry about it.
  7. Nov 11, 2023 at 3:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Seeing as you have a 2005 and the cabin filter is NOT wet, its likely the cab seam.
    There is a TSB on it for 2005 trucks. See the file below.
    It's possible its the antenna leaking. But that is rare.
    Jimmyh, 1bronco47[OP] and Micbt25 like this.
  8. Nov 11, 2023 at 4:14 PM
    1bronco47
    Thanks for all this info. Looks like i know how i will be spending my sunday. lol Ill give it a shot and update this thread based on the results!
    TnShooter[QUOTED] likes this.
  9. Nov 11, 2023 at 4:28 PM
    TnShooter
    Deogee
    STOCK
    Have you ever had the windshield replaced?
    They either leak soon after they are placed or years later.
    Like 5-10 years later. If the person removing the windshield scratched the paint too much, it can lead to rusting and a leak years later.
    That is another common reason for a leak in the floor board too/
    1bronco47[QUOTED][OP] likes this.
  10. Nov 12, 2023 at 12:16 PM
    1bronco47
    I have not. However i need to. My insurance will only cover it if it is smashed though. Thus why i am not super motivated to change it. But if its the reason for the water then im definitely replacing it.
  11. Nov 12, 2023 at 12:33 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Mine was leaking at the top of the windshield. Would fill the sun glass holder, leak into the cup holders and the passenger floorboard. Windshield wasn’t damaged. When I got it replaced they said whoever did it before must not have had the right seal. They cut the seal into pieces and tried to make it work by filling the voids with extra sealant which then dried and cracked and left gaps around the windshield. Glass shop said it happens with mobile installers sometimes. Make what you have work or risk the consequences of an upset customer and boss because you don’t have the materials to do the job on hand.
  12. Nov 12, 2023 at 1:21 PM
    1bronco47
    So after trying the water bottle method and seeing nothing i think i am going to schedule a new windshield. Like i said, i need one anyway but hopefully i kill two birds here. Thanks for all of the replies guys. If the windshield ends up fixing the issue, i will update here.
    TnShooter likes this.
  13. Nov 12, 2023 at 1:25 PM
    TnShooter
    Deogee
    STOCK
    My windshield was less than my $500.00 deductible.
    I think it was around $250. But that was about 7 or 8 years ago.
  14. Nov 12, 2023 at 1:33 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Call Safelite and see if your truck can be used for a training class and get it fixed for free.
    Steelhead Bum likes this.
  15. Jan 8, 2024 at 4:12 PM
    1bronco47
    Hey everyone, i wanted to respond to this thread to update you all on the resolution of the water issue in my cab. I had the windshield replaced (technically twice because safelite screwed it up) and that fixed my water issue. I wish i was able to find the area where the water was coming in but at this point i am just glad that it is finally fixed. Thanks to everyone who responded here!
  16. Jan 9, 2024 at 5:09 PM
    TacoTuesday1
    SD CA
    wow. Replies about sunroof drains for trucks that don’t have sunroofs.
    -avoid safelite
    -put a shield on your cabin intake
    -inspect the area for cracks
    -verify the cowl is installed properly and without gaps. Toyota has a TSB for this. They are on cowl revision 4
    -make sure nothing else causing it like an unsealed snorkel bracket
  17. Jan 9, 2024 at 5:31 PM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    Common problem. There's several threads covering causes/solutions.
