Water in Rear Diff??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MMazz365, Sep 7, 2011.
  1. Sep 7, 2011 at 2:57 PM
    MMazz365
    MMazz365 [OP] Well-Known Member
    Michael
    NY
    TRD Off Road
    -flowmaster dual side exit exhaust -3 inch lift -cb radio -scanner -DTRL's -Fogs Anytime -Truxedo Soft Tonnahu Cover -eyelids -grillcraft upper and lower -fogs behind the grill
    Well today in upstate new york we got flooded again, but this time worse than that whore Irene. I went outside to go to my cabin from college, and the parking lot was a river. my truck sat in water almost 2 1/2 ft deep. my only option is to push through it to get out. It was bad, bec guess whats sitting in my back seat; all the materials to do the Rear Diff Breather Mod.... Fucking bastard i was too lazy and busy to do it.... how do i know if i have water in my rear diff without changing out the oil?? oh and after going pretty much though a river my brakes felt funny and were really stiff.. why??
  2. Sep 7, 2011 at 3:16 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    nobodyyy??
  3. Sep 7, 2011 at 3:16 PM
    06taco
    06taco Well-Known Member
    Brendan
    South Jersey
    08 4x4 4-door TRD Sport
    *TRD Supercharger *3" OME lift kit *Dakar rear leaf springs *Total Chaos UCA *TJM T15 Plate Bumper *TJM Stealth 9000 winch
    I was worried about the same thing because after Irene I was traveling in water that was up over my diffs. Today I changed the fluid in my rear diff and didn't notice anything that resembled water coming out, I figured better safe then sorry. While I was at it I did the rear diff breather re-locator too, very easy only took me about 1/2 hour. I would say while your doing your rear diff breather you might as well change the fluid, just my two cents.
  4. Sep 7, 2011 at 3:18 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    yeah i guess im just going to have to go home this weekend and change my fluid, and yeah I did my brother tacoma in colorado with the rear diff breather and it was easy as hell, but ive just been busy with starting school
  5. Sep 7, 2011 at 3:19 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    What do you want us to say?
    So change your diff oil already....
  6. Sep 7, 2011 at 3:23 PM
    Us3r
    Us3r Reading...
    Socali
    98 Tacoma Std. 2RZ-FE 2WD
    Axle wrap mod (Shackled), 140 Amp Alternator & Wires, HID Headlights, Brush Guard Grille, Hella 550 Driving Lights. |Saving:Total Chaos.|
    if you want to find out if you diff fluid is contaminated. Crack open the drain bolt and drain it out. Oil and water can not mix, so water will be floating on the top. If all looks normal you can reuse the fluid (I don't recommend reusing any fluid).
    I say drain it anyways and change out the fluid, save you headache and any possible doubts.
    do the breather mod. it'll put you more at ease.
  7. Sep 7, 2011 at 3:23 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    totally off topic... but did you take a boat to class or walk through the water?
  8. Sep 7, 2011 at 3:23 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    well Mr smarty pants, i was wondering if there was an different way to check it
  9. Sep 7, 2011 at 3:24 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    alright ill do that thankss
  10. Sep 7, 2011 at 3:25 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    haha well it was more like a flash flood, but i could have taken a boat to my truck after classes got cancelled.... little cars got messed up bad lol... thank god for lifted trucks
  11. Sep 7, 2011 at 3:26 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Well, sorry for only trying to help you out...lol. :D
  12. Sep 7, 2011 at 3:27 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    x2
    and also, please remove your fill plug BEFORE you pull the drain plug :thumbsup:
  13. Sep 7, 2011 at 3:29 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    I can't think of much that I would rather do than kayak to class :anonymous:
  14. Sep 7, 2011 at 4:11 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    4.88s w/h rear Powertrax locker, Fox 2.5 Ext. RR COs, Camburg 1.25” ucas, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, 315/75/16 BFG KM2, 16x10" custom beadlocks, BFF front hybrid, GSF rear HC, Relentless Fab ifs skid, BAMF lca skids, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, LCE Dual Comp clutch, URD ss, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, ARB compressor, Grillcraft, FXR TRS, T1 eyelids, 500 hellas w/h 6k hid conv., custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers, Weather Tech
    haha, ive done something similar to that before! :D
    and if it makes you feel any better OP, before i found out about that mod, i drove through water up to my headlights over a dozen times, been muddin in a watery mix up to tha doors more than i can count and when i finally changed the diff fluid it looked pretty normal to me! So from my experience the breather mod is a fail safe kinda thing but not necessarily needed! Hopefully you have the same luck as me
  15. Sep 7, 2011 at 4:37 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    If the water covered the rear axle while the truck was parked and not driven in it hot, then you are probably fine. Water gets in the diff. IF the diff. is hot and you drive through deep water. Water does not enter through the stock breater on top of the diff unless the spring inside is removed (it is a one way check valve and really not a breather).
  16. Sep 7, 2011 at 4:45 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    my experiance with older 4x4s is they have a filler plug u could just pop that off and stick your pinky down in there to see if the oil had water in it. 90w with water in it turns creamy/milky white.
  17. Sep 7, 2011 at 5:42 PM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    If the oil has water mixed with it and you have ran it a lot it should look milky.Expect early failure of weel bearings also.Those seals keep grease in but sometimes let water in.Milky oil is a good sign of water in differentials,transfer case,engine and transmission.
  18. Sep 7, 2011 at 5:47 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    just change it. if it has the original oil in it youll want to change it anyway since during the vehicle break in the diff oil will get dirty. i never wait till the 60k like they say in the manual
  19. Sep 7, 2011 at 5:50 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    No pics of the flooded parking lot? You fail man, you fail.
  20. Sep 7, 2011 at 5:56 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    Haha I was in a rush bec University PD was just about to close down the road lol Ill see if i can find any on FB
