Water in rear storage cubby holes behind seats
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hooper89, Feb 3, 2021.
  1. Feb 5, 2021 at 4:28 PM
    IndyTac
    IndyTac Well-Known Member
    Indianapolis
    2019 TRD OR DCSB w/JBL
    Total Chaos bed stiffeners CaliRaised bed tie-downs CaliRaised 0-degree, bolt-on rock sliders Meso Customs Gas Hole JDM console and dash organizer Ceramic front tint Ceramic windshield coating Ziebart underbody and rust proofing Taco Garage Dashtop Multi-Mount (DMM) Black SR5 Grille Surround Swap Tacos4cheap Grille Badge Redarc Tow Pro Liberty Brake Controller Car Solutions Anytime Camera Mod TacoMods Radio Knobs Desert Does It Seat Jackers
    Do you park on an incline? I saw another post on here a while back where someone had a problem similar to this. Snow from their shoes would get onto the rubber mat, melt, runoff, and wet the carpet. I think it was the infamous “taste it” forum where the guy found salt in his truck and couldn’t figure out where it came from.
    Hooper89[OP] and Spare Parts like this.
  2. Feb 5, 2021 at 4:35 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Close the door on a $1 bill and drag it around the opening; there should be a good bit of resistance on a tight seal
    shakerhood likes this.
  3. Feb 5, 2021 at 4:35 PM
    Hooper89
    Hooper89 [OP] Well-Known Member
    2016 White TRD Sport
    Nope its flat. Still stumped lol
    IndyTac[QUOTED] likes this.
  4. Feb 5, 2021 at 4:35 PM
    Hooper89
    ok that is something I can do
  5. Feb 5, 2021 at 4:38 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    That won’t work unless you use a Franklin
  6. Feb 5, 2021 at 5:53 PM
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    Also may want to check the vapor barriers inside the rear doors , if that plastic sheeting comes loose water will run inside the door and into the floor of the vehicle instead of venting to the outside . I’ve seen this many times . Have you done any work inside your door panels such as speaker upgrades or a recent body shop repair ? Worth a look
  7. Feb 5, 2021 at 6:21 PM
    Hooper89
    Nope but I need to get into one door because the damn window is rattling.
  8. Feb 16, 2021 at 9:04 AM
    Hooper89
    Still does it. The sills are dry the padding is dry the seatbelts are dry but there is moisture under. the rear floormats.
  9. Feb 16, 2021 at 9:15 AM
    Hooper89
    Ok just noticed the bottom rear corner of both rear doors is wet. What I mean is the plastic interior trim part. Wtf????
    so water is coming down and instead of draining it is coming in around the rear door bottom corners
  10. Feb 19, 2021 at 7:40 PM
    Hooper89
    bump finally found where the damn water is coming from
    Canadian Caber and shakerhood like this.
  11. Feb 21, 2021 at 4:59 PM
    UberDingu
    UberDingu Well-Known Member
    CT
    21 Off-Road AC 4x4 V6
    Chew and shakerhood like this.
  12. Feb 24, 2021 at 5:30 AM
    UberDingu
    CT
    Maybe I'm not seeing something here, but where was it coming from?
    Chew likes this.
  13. Feb 24, 2021 at 5:41 AM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    If you haven't already check the drain holes along the bottom of the doors to see if any are clogged. Would be odd for both doors to be that way but only takes a second.
  14. Feb 24, 2021 at 7:06 AM
    Hooper89
    It’s third brake light I finally found a little droplets coming down from up above. Going today to see how much they’re going to try to rape me at the dealer fix it.
  15. Feb 24, 2021 at 8:20 AM
    #35
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Wasn't that the first suggestion? Since it's almost always the problem on older 3 gens.
