Water in the bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12retire, Jan 12, 2018.
  1. Jan 12, 2018 at 9:53 PM
    12retire
    12retire [OP] •••••••••••••
    So Cal
    2014 TRD Off Road. Pyrite Mica
    After the storms here in so cal, i noticed a towel i had in the bed was soaked, i have a snug top tonneau cover thinking it was waterproof, or can it be coming from underneath the truck?
  2. Jan 13, 2018 at 1:16 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    I would think even if you install weather stripping, if the rain's coming down hard / long enough, water will get in. At least a little. I don't know that any cover is actually waterproof. Also it only takes a tiny piece of the towel to be exposed to a source of water, and it will get absorb everything.
    When I go to the car wash with mine, and the cover is on, I always get a little water around the tailgate area. I also never installed the supplied weather stripping.
  3. Jan 13, 2018 at 3:29 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    From my experience, no tonneau cover is 100% leak proof. Usually it’s a result of the corners never being water tight due to angles and such.
  4. Jan 13, 2018 at 3:40 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    You’re getting water around the sides or top of the tailgate.
  5. Jan 13, 2018 at 4:46 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    I’ve got a UnderCover SE and never had water in bed till a heavy rain came through the other day. When I opened it there was water. It wasn’t a lot but it was there.
  6. Jan 13, 2018 at 5:08 AM
    rpkean
    rpkean Well-Known Member
    Macomb, MI
    TRD Supercharger
    I have a tuxedo truxport tonneau and it's not perfectly watertight due to the corners as the poster above mentioned.
    That said I've always seen it 90% dry in the worst of rains.
    I don't think there's any water coming from under the truck given there aren't any obvious rust holes.
  7. Jan 13, 2018 at 5:19 AM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    After Hurricane Irma my truck was wet inside the cab. I don’t think you can keep rain out of anything if there’s wind involved.
  8. Jan 13, 2018 at 5:20 AM
    moondeath
    Pa, Gardners
    The bed is composite. There are some small drain holes, but doubtful any water is coming up through them.
  9. Jan 13, 2018 at 11:31 AM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    Mine gets a little water either in the cab end or at the tail gate end if the wind is really blowing, or if I go through the car wash and the dryer blows some water past those little seals.
