Water in the cab!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flyjpa, May 3, 2009.
  1. May 3, 2009 at 1:24 PM
    flyjpa
    flyjpa [OP] Active Member
    Texas
    ‘19 Cavalry Blue TRDOR
    Work-in-progress
    Greetings! I'm new to the forum...mostly been lurking and staying on the sidelines, enjoying the helpful advice and humor.:)
    My '07 Double Cab has a bad case of water intrusion! Went to clean the truck after a heavy rain and found the pass. side carpet all wet!!! :confused:
    Pulled the carpet and found the insulation under the carpet soaked. The drain plugs are intact and seem to be making a good seal. Anyone else have this perplexing problem???
    Thanks for everyone's insight and advice!!!
  2. May 3, 2009 at 1:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw!!! sorry to hear about the water problem man. try looking around the firewall...and also the windshield seal to make sure there arent any bad spots. some other people have had this problem too....im sure someone will chime in and be able to tell you more.
  3. May 3, 2009 at 1:31 PM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    Could it be coming from the roof and running down from somewhere???
    Welcome!
  4. May 3, 2009 at 1:36 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    You might try the search function.....this has been discussed quite a bit here!
  5. May 3, 2009 at 1:40 PM
    flyjpa
    Texas
    Work-in-progress
    Thanks all for your replies! I am looking at the door seal as a possible culprit. Also, the drain plugs may be allowing water in. A lot of trial and error to find out the cause. Does anyone know if this is a warranty item?
    Thanks!
  6. May 3, 2009 at 1:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it should definitely be a warranty issue.....if you are still within your warranty mileage.
  7. May 3, 2009 at 2:07 PM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Have someone use a water hose from the outside and (you) on the inside look for water coming in. Use a flashlight and listen carefully.
  8. May 3, 2009 at 2:41 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I'd guess door seals as well. They aren't the strongest in stock form.
  9. May 3, 2009 at 6:08 PM
    JAG
    JAG Well-Known Member
    Something similar just happened to me yesterday.... I was pressure washing the back driver side window, I open the door later and there is water all on the seats everywhere. I checked the window and it was completely shut.
  10. May 3, 2009 at 6:25 PM
    johnny12345
    johnny12345 Well-Known Member
    vancouver island, canada
    09 tacoma SR5
    Ding, Ding, Ding, Ding...... I bet thats it. I had the same problem with my 09. The dealer told me it was a faulty door seal. All covered under warranty. I asked for new carpets and what not and they said if they can't clean the carpets and dry the carpet properly they will replace it. They actually did a really good job and the truck smells like new and you would never kmow there was a puddle in there. And so far no more water problems.
  11. May 3, 2009 at 9:11 PM
    AZsand
    AZsand Well-Known Member
    I had a similar issue with the rear windshield. I just figured it came thru the slider. And in my case it was muddy water...so it could be worse. Nothing when i wash it, just the one time when i was wheeling in mud. Eh, shit happens.
  12. May 4, 2009 at 8:32 AM
    flyjpa
    Texas
    Work-in-progress
    All,
    Great info!
    I'm heading to the dealer and asking "WTFO!?" Maybe I'll leave out the "F" though! The insulation under the carpet is completely soaked so I'm hoping they will replace it. I'll keep y'all updated!!!
    OBTW, from a previous lurking session, I took the advice of a veteran poster and got the Bestop softtop for my DC. I'll post pics soon. Very happy so far...only minor gripe was a little water in the bed. Still working on tweaks and squeeks to get it completely right, but happy so far.
  13. May 4, 2009 at 6:56 PM
    tacoholic
    East Bay, CA
    Sweet! I'll be waiting!
  14. May 4, 2009 at 7:29 PM
    Jimirich
    Jimirich Well-Known Member
    Hawaii
    08 4x4 Dbl cab shorty O.R. pkg
    DTRL, Debadged, Donkey tethered in the bed that rips 142 db farts so I can piss off the neighbors and rattle the windows on my house when I'm parked in front.
    Do let me know how you like that Bestop. I'm thinking of a shell but my dog says it has to be convertible so's he can still stick his head around the cab and watch for goats.
  15. May 8, 2009 at 7:36 PM
    flyjpa
    Texas
    Work-in-progress
    Jimi,
    Like it so far. Nice option is the screen windows for the sides. Not purchased yet but will be in the near future.
    Like I said earlier...I do get some water in the bed but for the most part it keeps things relatively dry. I am still messing with it to try to dercrease the amount of water that gets in.
    As far as the water in the cab, the dealer ran it thru the wash several times (so he says) but found no leak. Brought the truck home and the carpets were wet again:mad: He told me the carpets were dried and that everything checked out. I'll be bringing it back to get them to dry and detail the carpets! Other than that, will have to continue to troubleshoot to figure this one out.
  16. Jul 14, 2009 at 6:06 PM
    fghtngsquirrel
    fghtngsquirrel Ka-freakin'-BOOM!
    Jacksonville, FL
    '08 4x2 Rad Red *SOLD*
    So I went out to vacuum my truck today, and I got a surprise. I have Tacoma mud mats, and when I lifted the passenger front one to take it out, water was dripping from under it. I checked through the holes in the carpet (for the mat hooks) and water is almost standing underneath. Checked all the other mats, and they're the same way, though the front two are worse. I smelled the carpets, and it wreaks of mildew. Oh, and it did rain today. The truck was purchased Sept. 2008 with less than 10K miles, so I'm pretty pissed off.
    This is not the first time I have noticed water in the cab. It seems like recently every time it rains, the windshield fills up with condensation on the inside. I plan on taking it to the dealership ASAP. Anyone have similar stories??
    UPDATE:
    Woke up this morning (I live in FL so it's HOT) and the damn carpets were still pretty saturated with water. I took the truck to the dealership I bought it from brand new today, and their response was, "Yeah, this is a pretty serious issue, so we're glad you brought it in right away." No kidding. They ruled out the windshield leaking, so they are keeping it through at least tomorrow and are pulling out the complete interior. I am absolutely sick about this situation, but I'll update when I find something else out. :(:puke:
