Water in the cab!
Discussion in 'Technical Chat' started by flyjpa, Jun 6, 2009.
  1. Jun 6, 2009 at 9:50 AM
    flyjpa
    flyjpa [OP] Member
    Texas
    07 Taco PreRunner Dbl Cab SR5
    Posted this issue on an earlier thread asking for help. Finally got to the bottom of the issue.
    '07 Dbl Cab under warranty 2x to the dealer for trouble shooting.
    After dealers second attempt to locate source of water entering the cab, the mech. discovered a small hole in one of the welds in the rear of the cab below the window. Weld was repaired and everything was returned to normal.
    Hopefully this ends, once and for all, the mystery of the soggy cab!
    Thanks for all the advice from the forum!
  2. Jun 6, 2009 at 10:05 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Hmmmm....not good quality control on Toyota's part. Glad ya'll found the problem!
