Water in the doors?
Discussion in 'General Tacoma Talk' started by Gumby, Nov 11, 2023.
  1. Nov 11, 2023 at 3:16 PM
    Gumby
    Gumby [OP] Well-Known Member
    Washington State
    SR5
    Just started a speaker upgrade in a 2023 DCOR and noticed some wetness inside the doors when I pulled off the panels and went to start installing sound deadening material. It’s not crazy, but there’s definitely a little bit of water. I live near Seattle, and it’s definitely been raining hard lately, but this is not something I expected. It’s all behind the vapor barrier/between the inner and outer steel skin. I found it on both front doors, but not on the back doors. It looks like there is a small drainage hole at the bottom of the door that communicates with the area between the inner and outer metal… I imagine this is intended as a way to prevent any substantial water accumulation, and what I am seeing is just condensation, but wondering if anyone else has seen this. Is there a concern for rusting out? Or is this totally normal, and nothing to be concerned about?
  2. Nov 11, 2023 at 3:27 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Normal and designed that way. The water/humidity that makes it past the window seals needs an exit route.
    Don't block the drain holes when soundproofing. :cookiemonster:
    soundman98 likes this.
  3. Nov 11, 2023 at 3:39 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Normal. My F150 had enough water in the doors to where it would slosh when you opened it! It's aluminum so I don't have to worry about rust but still a normal thing on vehicles.
