Water in the engine oil
Discussion in 'New Members' started by abilawchuk, Oct 24, 2021.
  1. Oct 24, 2021 at 2:25 PM
    abilawchuk
    abilawchuk [OP] New Member
    Allen
    2018 Metallic Grey Tacoma Off-Road
    None
    Just got back from my annual hunting trip in Northern Alberta and went to clean off the engine and engine compartment and found out the dealer (I had just taken my truck in for a synthetic oil change) did not replace the oil cap and I'm afraid water, mud and dirt entered the engine. I
    checked the oil level and it is at the high normal level mark but I don't want to drive the truck any further due to fear of any further engine damage.
    Lots of water, dirt and mud could have entered through the open fill spout.
    Has anyone had a similiar situation?
    Much appreciated,
    Al
  2. Oct 24, 2021 at 2:31 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    So they didnt put the cap back on? If they didn't I would have thought you would see oil sprayed everywhere. If you are concerened just change the oil and your'e good to go. Worry about the dealership after that
  3. Oct 24, 2021 at 2:38 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    It's happened before
  4. Oct 24, 2021 at 2:40 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  5. Oct 24, 2021 at 2:44 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    You'd have to put a lot of water in the crankcase to cause a failure. You're good.
  6. Oct 24, 2021 at 2:51 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Water is on the bottom first thing for the pump to pick up highly doubtful that kind of water got in.
  7. Oct 24, 2021 at 2:55 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Any work done I always inspect the area worked on before leaving
    I wonder how you drove that far and never looked under the hood??
  8. Oct 24, 2021 at 3:01 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    If it eases your mind you can crack the oil plug on the bottom of the oil pan because water is lower than oil.
  9. Oct 24, 2021 at 3:04 PM
    MGMDesertTaco
    You should notify the dealer of the issue and have them document it in case you have any future engine issues. You could change the oil a couple of times over say 500-1000 miles if you're really worried about, but I'll bet your engine is fine.
