Water Issues (A/C?)
Discussion in '1st Gen. Tacomas (1995-2004)' started by JimmyOh, May 11, 2014.
  1. May 11, 2014 at 5:21 PM
    JimmyOh
    JimmyOh [OP] Well-Known Member
    Jimmy
    NYC
    2014 DCLB LT
    Hey guys. So now that I'm running my A/C due to the weather warming up Ive noticed water coming out of the vents on the side of center console by my feat. The water only spills out when going hard around corners. Is there water in there that should be draining that isn't?
  2. May 11, 2014 at 5:29 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    check to see if your tube drainer on the right firewall is not pinched. access water from the ac system drain out from that tube.
  3. May 11, 2014 at 5:29 PM
    Madjik_Man
    Colorado Front Range
    Is your passenger side floor wet?
    If so, your evaporator box is located there. It's probably clogged.
    The drain nipple is on the engine side of the firewall just behind it. Get a coat hanger and gently poke it free. Water should drain out of it.
  4. May 12, 2014 at 5:26 PM
    JimmyOh
    Jimmy
    NYC
    2014 DCLB LT
    It ended up being a clogged drainage nipple. Thanks guys!
