Water Leak Inside the Cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Christolumbus, Jan 14, 2020.
  1. Jan 14, 2020 at 7:51 AM
    Christolumbus
    Christolumbus [OP] New Member
    2006 Toyota Tacoma 4WD Access cab
    Hi guys, so I have a 06 Tacoma, and I've recently started noticing that I have water leaking from the garage door opener/ sunglass holding. As well as from the light fixtures, both the front cab lights and the Middle cab light.
    I'm not sure why it's doing that, and I'd rather not year my car apart to find out, since I'm living in it currently.
  2. Jan 14, 2020 at 8:05 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    How's the gasket around the top of the windshield? Shark fin antenna? Those are the first two I would check.
  3. Feb 26, 2020 at 10:23 AM
    feed me adventures
    feed me adventures New Member
    2009 tacoma trd
    my '09 is doing the same. every time it rains i get a stream out of the sunglasses holder. have you found anything new on this?
  4. Feb 26, 2020 at 3:19 PM
    gasgasman
    gasgasman Well-Known Member
    Girard
    Texas
    You can , put the A/C on full blast,close all the windows and doors.
    Then go around and spray soapy water around the windshield, 3rd brake light and Sat antenna pod.
    Se if you see any bubbles. That's where the water intrusion would be.
    Hyperion likes this.
  5. Feb 26, 2020 at 3:20 PM
    Bishop84
    Bishop84 Well-Known Member
    Likely windshield leaking, possible rust. Get it dealt with sooner than later.
