Water leak on passenger floorboard
Discussion in '3rd Gen. Tacomas (2016-2023)' started by torqsky, Feb 4, 2023.
  1. Feb 4, 2023 at 6:16 AM
    torqsky
    torqsky [OP] New Member
    2016 Tacoma TRD
    Hey y’all. I have a 2016 tacoma (no sunroof) and just noticed there was a leak on the passenger’s side floorboard. It’s not wet on the top/side/or under the seat, just the middle of the carpet. Wonder if anyone had the same experience.
  2. Feb 4, 2023 at 6:20 AM
    aggr0crag
    aggr0crag Well-Known Member
    19 DCSB 4x4 Sport M/T
  3. Feb 4, 2023 at 6:25 AM
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    Another possibility could be the AC drain line.
  4. Feb 4, 2023 at 6:26 AM
    GeauxTacoma
    GeauxTacoma Well-Known Member
    Maryland
    2022 TRD Sport DCSB Lunar Rock
    Sunroof vent clogged
  5. Feb 4, 2023 at 7:04 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Read it again chief
    RIX TUX likes this.
  6. Feb 4, 2023 at 7:18 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Do you have a roof rack? I know on very heavy rain storms I've seen an occasional drip from the passenger grab handle that I assume is coming from the mounting holes of my OEM roof rack. I need to get in there soon and seal it.
    I've already had the third brake light seal replaced so I don't think the water is coming from that.
  7. Feb 4, 2023 at 8:50 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    all good points
    1. 3rd brake light
    2. A/C drain
    3. roof racks
    Either way, get on it, the 3rd brake light cleanups have been nasty on some occasions. If it's been leaking for a while, even if you haven't noticed until now, you could have a mold issue. Well,,,, any leak can cause this really.
  8. Feb 4, 2023 at 9:05 AM
    mcmcolem
    mcmcolem Google Search Mechanic
    Texas
    '18 Cement Taco
    I had this same leak. It was coming from the seam in the body/firewall that's underneath the carpet at the back-right of footwell. I had to take the carpet and insulation out, and look behind the electrical hub that's down there. I sealed it up with silicon sealant. Hopefully this is not your problem hahaha
  9. Feb 4, 2023 at 9:22 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    my leak was coming from a seam in the evaporator box. but i have also seen leaks due to clogged drain lines and clogged hvac intakes.
    LeakyAC and AODRN like this.
  10. Feb 4, 2023 at 10:29 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Most likely related to the A/C condensate drain. Check that it is not clogged. If the drain is clear, then you have a leak in the evaporator box.
    AODRN likes this.
  11. Feb 5, 2023 at 9:20 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    A little compressed air up the ac hose. Check for kinks.
  12. Feb 5, 2023 at 9:32 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    might want to blow it from the other side. you don't want to blow debris back into the evaporator box.
  13. Feb 5, 2023 at 9:33 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    This was also my issue. Cracked evap box.
  14. Feb 5, 2023 at 9:51 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    mine didn't have a crack in it, just seemed to sweat a lot. they patched it up with sealant at the dealership.
    LeakyAC likes this.
  15. Feb 5, 2023 at 10:01 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Yeah, same here.
    LeakyAC likes this.
  16. Feb 5, 2023 at 3:25 PM
    LeakyAC
    bingo
