Water leak recommendations
Discussion in '1st Gen. Tacomas (1995-2004)' started by mrdctaylor, Nov 9, 2023.
  1. Nov 9, 2023 at 9:39 AM
    mrdctaylor
    mrdctaylor [OP] Active Member
    I've been fighting a water leak on my 2002 Tacoma. I can't find it. I've had it into one body shop and they couldn't find it. When it rains and the truck is sitting outside, the driver's side carpet gets wet. I've checked the obvious stuff myself, replaced weatherstripping, made sure the vapor barrier is secured, etc. The wiring hardness passthru on the firewall is sealed up too. It isn't that. I really think it is making its way into a body seam somewhere. It seems to be wettest on the carpet near the kick panel by the driver's left foot.
    Anyway, I'm looking for recommendations and what to do next. I've reached the limit of what I can do myself. I'm thinking about calling around to local body shops to see if they are able to diagnose an issue like this. Or I could take it to the local dealer's body shop with the hope they have some Toyota-specific knowledge. Thoughts? Recommendations? Thanks!
  2. Nov 9, 2023 at 9:45 AM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Darrell942 likes this.
  3. Nov 9, 2023 at 10:04 AM
    02hilux
    Planet: EARTH
    Time to smoke out the cab, lol
  4. Nov 9, 2023 at 10:44 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Check your seams where the cab meets the firewall. Take a hose and flood the bottom half of the windshield into the cowling. Pull the carpet back and look for the wet. That’s how I found mine on the passenger side.
  5. Nov 9, 2023 at 2:01 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    U have a sunroof?
  6. Nov 9, 2023 at 2:01 PM
    mrdctaylor
    No.
  7. Nov 9, 2023 at 2:03 PM
    ControlCar
    Steven
    Sugar Land TX
    Dang
    Clogged Sunroof drain tubes cause your exact issue
  8. Nov 9, 2023 at 2:06 PM
    ControlCar
    Steven
    Sugar Land TX
    You need to search
    I would start by removing cowl/wiper arms and taking a look
    Possible the upper bolts to L fender too
    ugh just clicked/saw video
    Ugh I’m an idiot
  9. Nov 9, 2023 at 2:49 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Pull the carpet up in that area pull the glove box out and take a flash light and look from the inside as someone take a garden hose to your car.
    Darrell942 and araknon2022 like this.
  10. Nov 10, 2023 at 5:15 AM
    mrdctaylor
    Yeah, I've tried this. It must be a slow enough leak that it takes a long time to make its way into the cab. When doing this I've never been able to find a leak, which is probably why the body shop had a hard time too.
  11. Nov 10, 2023 at 6:50 AM
    noodles93
    Charleston, SC
    Have you ruled out the windshield? Spray some soapy water on the outside and blast some air on the inside along the seal
    michael roberts and ControlCar like this.
  12. Nov 10, 2023 at 6:59 AM
    mrdctaylor
    That's great advice! I hadn't thought about doing a leak test that way. Thanks!
  13. Nov 10, 2023 at 4:01 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    I just tried to search for you, fail. There is a fairly recent thread here in which someone had a leak, chased all through the windshield, vents etc., no luck. Someone suggested the door. What happens (apparently) is if the vapor barrier is loose or was never re-attached, and water doesn't flow out the drain holes at the bottom of the door as it should, it flows inside the door and into the cabin. It may not be the source but I wouldn't overlook it, when it's wet feel along the bottom of the door for moisture.
  14. Nov 10, 2023 at 6:31 PM
    mrdctaylor
    Thanks, man! I really appreciate that. However, I did already check the vapor barrier. I sealed it up VERY well. I think the water is flowing through the door like it is supposed to, but it does seem wet on the carpet near the door. <shrug> I probably need to run water down the door and check that again. Thanks again.
  15. Nov 10, 2023 at 7:00 PM
    Rhodes
    Rhodes Well-Known Member
    Edmonton
    01 Dbl Cab
    I had the same frustrating issue. There’s a report about a leak in the firewall/ cowl. I followed those directions with some sealant but it still was wet inside after some rain.. it must have been happening for years with the PO unaware.. I ended up having to cut out a big section of floorboard and weld a patch, changed out the carpet too because it just stunk.
    I tried the garden hose idea but still didn’t find it. I swapped the door seal out, had a new windshield put in anyways, and got them to dbl down on the sealant. Plus I redid the sealant under the wiper cowl. Seems to be good now, but I can’t narrow down what it actually was…
  16. Nov 10, 2023 at 7:05 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    Agree with the windshield suggestion, especially if it's ever been replaced.
