Water Leak....
Discussion in '1st Gen. Tacomas (1995-2004)' started by xtimesofgrace, Feb 13, 2012.
  1. Feb 13, 2012 at 4:34 PM
    xtimesofgrace
    xtimesofgrace [OP] New Member
    I have a 96 tacoma 2.7L. I tried to go somewhere the other day and the truck would not turn over. It was very cold and has not been driven in about 3 days so i figured the battery was completely dead (the battery is 7 years old). I bought a new battery, put it in, and it did the same thing. I pushed the clutch and let the truck roll back and just tried to turn it over again and it started. The truck has NEVER overheated but it is losing water. I got the truck towed to a Toyota dealership and they said it is more than a blown head gasket. He said he put water in the radiator and took out the plugs and turned the truck over and said it was spewing an excessive amount of water from the plugs. The mechanic said in his opinion the engine wall could be cracked and that i would have to get an entire new engine. He also said that it would cost $600 for them just to take apart the engine to see if it is cracked and if it isnt it was a blown head gasket and would be around $1200. Another mechanic i spoke to at a different dealership said it could be leaking that much water based on how blown the head gasket is. All in all it would be around $5500 for a new engine and labor according to this dealership. I am wondering if this price is a little ridiculous or should i just get a new vehicle all together.
  2. Feb 14, 2012 at 9:56 AM
    300k96Tacoma
    300k96Tacoma Well-Known Member
    Weaverville NC
    96 Reg. cab 4x4 Tacoma
    Stock-300k miles
    I would try to find a low mileage engine and get a local mechanic to put it in for you. A dealership is far too expensive for this kind of thing. How many miles are on the truck?
  3. Feb 14, 2012 at 12:35 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Lazy dealership is trying to extort you. 1-2hrs labor to diagnose an engine. Leakdown check will find leaks in the head and cylinder.
    Leakdown tester is under $50 from harbor freight. Directions are online. You will need an air compressor, mechanical ability, and a breaker bar to turn the engine by hand.
  4. Feb 14, 2012 at 1:42 PM
    xtimesofgrace
    its has about 185k on it. i bought the truck because a friend of mine has a 99 tacoma with the same engine and his has 300k and he still runs the hell out of it.
    and also this isnt a project that i would be able to do myself i do not have the right stuff or the time to do it. i think the dealership is just being lazy and taking the easy way out for them which would be to replace the engine block. i find it hard to believe that the engine wall would be cracked. i take very good care of my truck and i dont even offroad with it so it is never abused.
  5. Feb 14, 2012 at 2:23 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    An exhaust gas test of the coolant will tell you if you have a compression leak into the coolant: crack or head gasket leak.
    I forgot to ask if your water pump shaft seal leaks, or if you inspected the radiator, hoses, etc for leaks. Heck, a pressure test will find those too.
    No external leaks? Odds are, it's the head gasket. Take it to another dealership that's not trying to bend you over!
  6. Feb 14, 2012 at 6:17 PM
    ratso
    ratso Well-Known Member
    northern ca2
    sr5
    Camburg coilovers,ARB, warn 9000,avic d3,KN cold air,poweraid, optima yellow top,line x
    How do they look? They will be shiny and clean if a blown head gasket exists.
